  • Replies 305
really?? hmmmmmmmm
na, i think the boss would kick my ass, if it was mine, i would.
i could always put wendys auto lancer on the rollers? no shit, i reckon that thing has about 13fwkw ! pos
Going to the next modern Reg' chad?
It's the day after the dyno day (15th)
Nope, I want to try and enter the time attack at the end of the month.
Hey Chad, yes if you request to be put on first thing that shouldn't be a problem, just note it on your entry form I think.
I'll have a chat to GW about it.
are you still trying to put the club members together against the Jz boys
Matty 31, should be plenty of spots left, call GW as they will be able to tell you.
Madaz, im not one of the organisers sorry, that would be best directed at Dan, BLU555.
The classes are still going ahead (RB vs JZ), but i don't think they will be back to back. so if DSTROY makes the most out of the RB's early morning well he'll still be the winner.
the days, although busy arn't heaps strict so if things can be juggled around to suit everyone as best as possible that's what happens :(
Edited by BlitzSSS
Chad,
If you need to get on early, I can organise that, no problems. As Paul said, there can be some suffling around of places too to accomodate entries.
Thanks for your supprt guys too. It's great that irrespective of the club, we can all get together and enjoy our cars. Oh yeah, expect some very heavy hitters from the GSR Evo club too!
Cheers
Daniel.
Chad,
Cheers
Daniel.
So is there anyway we can know before the day what times our runs are?
i know this starts at 8 and i will try to get there before then but just wondering if
there is someway of knowing when my run is thats all
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
