  • Replies 305
Bugger.
That surprise isn't happening now :blink:. Well, Damon, the other guy who helps me organise this day, is mates with GT George, and he was going to come down in his drift R34 for you guys, which is now sporting a single turbo LS1.
Sorry.
Still, we'll see what else he can bring for a show.... :P
Edited by BLU555
That 34 is mental.
Pretty sure that's the same one down at AJD last year?
Either way, the sound of that thing was INSANE.
Yeah thats the one. It did a startup at Autosalon too, thing is off its guts. But as above, apparently its only single turbo LS1 now? what a let down :P
The R34
http://www.gtautosound.com/gallery/thumbnails.php?album=101
just a lazy 514kw
The S15
Lol, I've driven the R34 off the back of the truck and onto the hoist. Best 30 seconds of my life! And I helped Theo jump start the S15 after he nearly put it through the fence at the end of their street. Race gas stings your eyes :)
any chance you can see if i can get a $10 refund to be used for BBQ and Drinks :D
my registration details as follows Stevan Rosskogler registered for a AWD will now be running a FWD
cheers
EDIT
oh just read your post Damo ill take your car if theres no takers either way $10 refund or you buy my slot and run the 34
ah crap, just realised i listed my car as AWD (until i had a read and discovered my understeer is caused by it having 75 profile rubber and not the fact of fulltime 4wd) so im technically in teh RWD class...........is that a biggie?
or for shits and giggles chuck it into 4H on the dyno :)
HA! No biggie at all, just let Brett and Shaun know when it's time for your run!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
