  • Replies 305
all paid for... time to spin some rollers :D
cranked boost up to 11, wow what a difference. slight misfire gonna be a problem on the dyno? coil packs are a bit worn :(
you running standard ecu marko?
Umm whats the gapping on your spark plugs marko
if they are at a standard gap then take them out and regap it to 0.8mm
that should solve the problem
Could be plugs, what gap you running and how old are they? NGK BCPR6ES are a good plug for the 25 and come pre gapped to .8
Best thing is they are only 26-30 bux a set.
Add another 10 to that then they start to boogie!!!!
standard ecu, standard coil packs, hybrid front mount, trust 3.5" cat back, in line boost controller @ 11psi on stock turbo, pod filter
ive taken the coil packs out yesterday and insulated them with good quality electrical tape, the plugs were 1.1 but ive re-gaped them to .8 and they're only about 3,000km old. Will be getting some insulating silicone over the weekend for the coils as well as new .8mm plugs + get the afm cleaned up.
hoping it will solve the issue. apart from that im looking in to a toshi remap or safc once i get the rest of the exhaust, injectors and fuel pump. cant be bothered with a whole new ecu as i'm not after much more power so don't really see the point in spending over 2k.
well i hope you get the car running sweet as marko for the dyno day
ahh well you got about a week to get it happening then mate
should see a decent power figure out of that
one would assume so Wayne Daniel only posted up yesterday there were a few spots left... and worst case scenario ill sell my spot on the day if someone missed out
AWD = $50
FWD, RWD = $40
call up Graham West Workshop and sort it out, or drive in, fill out the form and give em the $$.
668 Marion Rd
PARK HOLME
SA, 5043
(08) 8277 5688
and my misfire is sorted :(
Edited by tx3_90
yeah drop in on the day there are always things that keep people attending so there are always spots to buy on the day and as i said earlier worst case scenario ill sell my spot
hmmmmmmmmmm ill decide on the day........
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
