  • Replies 305
all paid for... time to spin some rollers :D
cranked boost up to 11, wow what a difference. slight misfire gonna be a problem on the dyno? coil packs are a bit worn :(
you running standard ecu marko?
Umm whats the gapping on your spark plugs marko
if they are at a standard gap then take them out and regap it to 0.8mm
that should solve the problem
Could be plugs, what gap you running and how old are they? NGK BCPR6ES are a good plug for the 25 and come pre gapped to .8
Best thing is they are only 26-30 bux a set.
Add another 10 to that then they start to boogie!!!!
standard ecu, standard coil packs, hybrid front mount, trust 3.5" cat back, in line boost controller @ 11psi on stock turbo, pod filter
ive taken the coil packs out yesterday and insulated them with good quality electrical tape, the plugs were 1.1 but ive re-gaped them to .8 and they're only about 3,000km old. Will be getting some insulating silicone over the weekend for the coils as well as new .8mm plugs + get the afm cleaned up.
hoping it will solve the issue. apart from that im looking in to a toshi remap or safc once i get the rest of the exhaust, injectors and fuel pump. cant be bothered with a whole new ecu as i'm not after much more power so don't really see the point in spending over 2k.
well i hope you get the car running sweet as marko for the dyno day
ahh well you got about a week to get it happening then mate
should see a decent power figure out of that
one would assume so Wayne Daniel only posted up yesterday there were a few spots left... and worst case scenario ill sell my spot on the day if someone missed out
AWD = $50
FWD, RWD = $40
call up Graham West Workshop and sort it out, or drive in, fill out the form and give em the $$.
668 Marion Rd
PARK HOLME
SA, 5043
(08) 8277 5688
and my misfire is sorted :(
Edited by tx3_90
yeah drop in on the day there are always things that keep people attending so there are always spots to buy on the day and as i said earlier worst case scenario ill sell my spot
hmmmmmmmmmm ill decide on the day........
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
