Hi guy's, I have just bought myself my first skyline and it has D2 coilovers currently on the car. The ride seems extremely hard..
The guy who had before me has the car sitting fairly low. Has anyone had them? and if so were they able to adjust them to a comfortable drive? Or are they fairly bumpy coilovers? The car also has adjustable camper and castor and sway bars.
https://www.sau.com.au/forums/topic/248628-d2-coilovers/
I believe changing to softer spring usually means it needs to be revalved.
Most coilovers are good for track only so you should get them changed. Overly bumpy ride can cause problems.
Go for coilovers with 6 or 5KG spring front, and 5 or 4KG rear (6/5, 5/4) and you'll get a firmer ride without the exessive harshness. D2 and G4...etc coilovers are usually around 10KG, which is way to hard for the dodgy sydney roads.
https://www.sau.com.au/forums/topic/248628-d2-coilovers/#findComment-4315275
Thanks, I thought that might be the case. Oh well, I think a set of teins are in order.
https://www.sau.com.au/forums/topic/248628-d2-coilovers/#findComment-4315434
I have D2s on my car... actually strikes a good balance in my opinion. They are damper adjustable... not sure if its bound/rebound .... but just thought id add my 2 cents...
Ive heard that some teins are ridiculously firm also... so make sure you do your research before you buy.
https://www.sau.com.au/forums/topic/248628-d2-coilovers/#findComment-4325224
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
