Not quite - area = pi*r^2, so:
3" pipe = 4,560mm2
2x2.25" = 5,130mm2
2x2.5" = 6,333mm2
5" pipe = 12,667mm2
so as you can see, 2x2.5 is definately not as much area (flow) as a 5" pipe by a long shot
What i was trying to get at is that you'd think that 2x 2.5 inch pipes would flow more then a single 3" pipe!! Probably wrong though for not the first time!
  • Replies 47
Posted Images
Well you were on the right track - 2x2.5"s would flow a lot more, but its a lot more surface area than a single 3" and would take more space under the car.
A fairer comparison would be Comparing similar sizes (say 2x2.125" compared to 1x3", both 4560mm2) the flow is almost the same.
Well all i know is this exhaust compared to the trust PE2 this revs up quicker and makes more boost with out changing the settings with the sacrifice of it being almost doubly as loud
but those of you that heard the 4" that i ran for a little bit it isn't quiet as loud as that
instead of having 1 large pipe to get all the flow out of ive gone for a split to keep it high off the ground whilst keeping the flow something a little different too :)
I've got a 3 1/2 inch zorst with a massive center muffler and a hi flow cat and i have no clearance trouble at all, i just took my car to a a good zorst shop and got them to cut it and push the zorst up as hight as they could get it then re-weld it, now i have no problems at all :P
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
