Hi guys, im looking at buying twins for my r32 gtr and not sure what to buy. Im looking
at response not laggy turbo's, i was thinking of r34 gtr n1's or something similar. what do
you fellas think i should get.
Thanx heaps for your input :D
https://www.sau.com.au/forums/topic/248895-what-twin-turbos-do-you-recommend/
The -5 is a 360hp turbo with a larger compressor wheel so more lag.
The -7 is a 310hp turbo that is more responsive.
So -7 = very roughly 250-320rwkw
-5 = 330-400rwkw
I'm planning to go the -5 due to the fact I just built my engine stronger and I have 2530's that need replacing.
There is more info on comparisons of turbos if you do a search.
cheers.
I just chuckled at the delay in posting times LOL.
Slide performance on these forums (SAU trader) had them for sale for $2545 for the pair plus actuators.
This was for -5 and -7's.
anyone know what they are worth?
See above post for a price from a forum seller, also have a look at the 2860-9's, HKS GTSS equivalent, not sure where to get them though...
Thanks Sean
Garrett GT2860R-5 in stock
Garrett GT3860R-7 in stock
HKS GTSS kits in stock
HKS GTRS kits in stock
Greddy T517Z turbo kits in stock
HKS GT2530 GT Sports Turbo Kits in stock
Big or small we have the lot in stock and ready to send with details please click one of the above links.
:P Aaron
