Hi guys, im looking at buying twins for my r32 gtr and not sure what to buy. Im looking
at response not laggy turbo's, i was thinking of r34 gtr n1's or something similar. what do
you fellas think i should get.
Thanx heaps for your input :D
https://www.sau.com.au/forums/topic/248895-what-twin-turbos-do-you-recommend/
The -5 is a 360hp turbo with a larger compressor wheel so more lag.
The -7 is a 310hp turbo that is more responsive.
So -7 = very roughly 250-320rwkw
-5 = 330-400rwkw
I'm planning to go the -5 due to the fact I just built my engine stronger and I have 2530's that need replacing.
There is more info on comparisons of turbos if you do a search.
cheers.
I just chuckled at the delay in posting times LOL.
Slide performance on these forums (SAU trader) had them for sale for $2545 for the pair plus actuators.
This was for -5 and -7's.
anyone know what they are worth?
See above post for a price from a forum seller, also have a look at the 2860-9's, HKS GTSS equivalent, not sure where to get them though...
Thanks Sean
Garrett GT2860R-5 in stock
Garrett GT3860R-7 in stock
HKS GTSS kits in stock
HKS GTRS kits in stock
Greddy T517Z turbo kits in stock
HKS GT2530 GT Sports Turbo Kits in stock
Big or small we have the lot in stock and ready to send with details please click one of the above links.
:P Aaron
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
