Well it seems that at my last outing to winton raceway my turbos decided that enough was enough.
so im now looking to upgrade a bit. the thing that im having trouble deciding weather to stick with the twins setup or to go big single...
if its going to be twins, im looking at the garret 2860-7's.
i want something that going to give me good power/torque, without sacrificing response. the car does see a bit of track work...
but ive always liked the idea of the single turbo with the external gate screamer (love the noise!!!).
has anyone got any suggestions on what i can go for?
cheers.
matty.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/
You know what, i was gonna go for the HKS gt-ss kit but with all the trouble from EPA today its best to for for garrett stuff because if you do wind up in a testing booth, they will only see the garrett logo and think its stock.
everyone so far is saying the -7's are the bomb for track and street + add some cams for a little extra top end and your there.
I wanted a big single sooooo badly for the gate and look but honestly, after my recent exhaust EPA im sick to death of dealing with all the bullshit so stick to the lowmounts.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4321588
Ummm have you even looked @ GT-SS turbos?
They only have Garrett markings on them, Garrett housings etc.
Fact. Ive seen them, i have them.
Either way, GT-SS are not affordable anymore with the yen the way it is.
-7's all the way. You don't need cams.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4321684
so it looks like im on the money then. :(
its currently got the N1's on it, with 20 psi of boost the car made 310kw at the rears. what sort of power should i expect to se out of the 2860-7's with similar or less boost?
a bit of a curley one i know but im just after a ball park figure. im hoping for about 350kw (bearing in mind im getting larger injectors done at the same time.). do you think im dreaming, and what size injectors should i go for?
cheers.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4322168
near enough to the same really, GT-SS make around 330rwkw or so.
Depends on the dyno more than anything.
The -5's (next step up) will make 350, but they are good for a bit more, but then you hurt response so thats where the question lies
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4322354
it seems the that -7's are the go,
would 700cc injectors sufice, or would i need bigger?
also is it worth spending the extra money on cams as well, or will the good ol' standards do the job?
700cc is fine, and standard cams will work a treat ;)
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4323083
NA - Not Applicable! :bunny:
As for you conrad... i suggest rather than buying really expensive STI parts to make your car something its not, just get the genuine article. or at least get a real car... you can only abuse an "STI enhanced" badge so much! :bunny:
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4324327
Shepo - I would have brought an STi, but the bank was being a complete tightass that day!! And "Expensive" parts?? That's what I have you for!!! Full retail is for chumps... And who needs an STi motor... I have my SHARPIE TUNE to take care of that department!!!
But then again. Whose car is running...? Hmmmm?
Edited by theDOG
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4324605
  • 3 weeks later...
Just thought i would update for those who may be interested.
im going ahead with the 2860-7 turbo's. also sard 800cc injectors (probrobly overkill, but better safe than sorry in my opinion.) and lastley getting a trust stainless steel intake piping kit.
once done, should be good for a bit more power. :P
will keep you all posted as things progress along. let me know your thoughts.
cheers,
matty.
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4352916
cheers,
matty.
my thought on getting 800cc injectors: :P
https://www.sau.com.au/forums/topic/249121-hmm-what-to-do/#findComment-4352946
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
