BP East Perth appeared to have plentiful U98 bowsers this morning as I drove past.
gazza, how long have you been using vortex98 for? I put half a tank in once as a last resort but other than that I always run U98 regardless of cost. I didn't buy a skyline and then modify it to be economical and saving $5 on a tank of a fuel is meh.
  • Replies 98
Posted Images
I've been using vortex98 since it came out (business fuelcard). No difference in performance or engine wear etc... and saves me having to travel to thornlie to fill up (closest bp).
ERRRR, that station is in HUNTINGDALE, not THORNLIE.
*mutters rude words at thornlie*
The story I got with the covers on the 98 (usually happens with the caltexes along sth street at the same time) was that they only get rationed a small amount, so when they run out (tanks get low..not empty) they whack the signs on and force people to fill with 95 or 91. I also got told that the 98 all comes from the same place...
The petrol stn guy did offer to let me fill with 98 but said it'd be dodgy quality due to being bottom of tank stuff.
yeah im still stickin with the tags were out coz they didnt want people using the fuel till the prices were up, i highly doubt they would have all been out of 98 an the caltex's, which use the same fuel, are full, morely just sounds like the luck of the draw with that.
As for my near tow, strich, i ventured for fuel when my car got to a good 8th of a tank left, i arrived at the caltex with the fuel light on
Haha, forgive me. Area is full of bunkies... At least the local servo dude tells me when they get fresh 98 :(
I don't use BP. (not that i have to in car)
I find they are dogey pricks all the time, the bp's near me charge the same price for E10 Fuel as other petrol stations charge for 91 octane.
plus the Bp near me doesn't have 91, and their pumps are always closed.
i'm caltex kid or the private one near me house, his prices are good, he doesn't bump them up on a monday or friday. so i usually go to him on weekend if i have too.
for all those vortex 98 haters, let me tell you a little secret, last year before the Australian National Championships, we had all three 98 octane fuels (BP, Peak and Caltex) tested from three different petrol stations for each brand and guess what, the average octane rating in the Caltax three samples were higher than Peak which was higher than BP.....
I run only vortex 98
Interesting..
Consistancy is still an issue with me, if someone could do that test every month for a year then I could be converted but until U98 bites me in the ass I will continue to use it as I know it is reliable.
Isnt there only one refinery in WA that can produce 98octane?
yes but the vortex 98 blend is a different blend than ultimate 98
bp and caltex have their own blends done at the same refinery
i have been using vortex98 since it came out with no problems and i wont say fuel caused my big end bearings to crap themselves thats an oil control prob
Edited by gazza750
100% sure it was oiling and not detonation from shit fuel?:blush:
BP Woodvale 97.5c per litre
BP Wanneroo about 2 mins away, 108c per litre
f**k your consistency bp, I've got about half a tank left so this shit better be sorted one way or the other by the weekend ;)
Use Bp sometimes, Caltex sometimes (more a while ago as work was paying with the fuel card) and for the saturday's entertainment had a full belly of United 98. The bunky doesn't really give a rats about what I put into it, slurps it down and makes smoke and funny noises from the tyres (350rwhp so not entirely lethargic). Knock levels were the same as any I'd seen previous. I must say that I like the smell of caltex98 better.. smells sweeter, must be the aromatics. ;)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
