ok iv had my R32 GTR for 3 weeks now and bought a E11 V2 haltech,front pipe for it.
the mods for the car stand at
haltech ecu
s/s front pipe,3" all the way with one big resonator and a jap spec muffler at the back9system is not perfect by any margine and still runs the compliance cat
apexi suction kit(still runs the air flow metres(disconected)
cooper plugs
exedy h/d clutch
profect b boost controler running 14psi
the car also runs 20"x10" wide which i was told isnt to power friendly.
this is about it,the car made 293.4 HP
the machanic who is justin at CTP qld said the motor probably isnt standand as they dont make that power.
i cant thank justin enough for the work he did and will be using him again....thanks mate
https://www.sau.com.au/forums/topic/249254-dyno-and-tune-on-my-new-32-gtr/
Considering 60 degree intake temp (adding a nice correction, read - higher number) and 218rwkw.. its certainly not the highest result for 14psi we've seen, more towards the lower end if anything.
People have made 240-250rwkw on 1bar (14.5psi) easily enough time over.
As for the motor being modified - i highly doubt it. To make an assumption like that really isnt the best as there is no indication from a result thats a bit low
Im not saying its a bad result, however its nothing overtly better than anyone else.
You need to change the cat, and get a set of cam gear's on there... then see how it goes. Should be up closer to 240rwkw like everyone else with a nicer midrange
well this is a nice way to burst my bubble....
yeah its i big deal to me as this is my first GTR as i come from rotary and v8 side of the car scene.i use to own one of australias fastest drag rotor and didnt epect much from the dated datto.
iv got HKS step 2 cams and gears and full fuel system to go in as well as a to4z.but wanted to know what it would do before the mods.this is my day to day car so i didnt think id star with a hell of a lot.
scotty
Not really bursting the bubble - the dyno results thread would confirm what most are saying here.
T04Z on a stock motor?
I'll say a prayer for you tonight mate when i talk to my blown engines in RB heaven ;)
I made 230awk with PFC, pods, front pipe + 3" ex, very little cam gear adjustment. @ 0.9bar (13psi)
tuner tells me he had a run of 275awk when boost didnt hold and spiked at 1.4bar (20psi) which is where he lost the AFR's readings. As we are not sure on the ex turbines on my car I keep it at the tune he dialed in.
get ready to empty your wallet as it doesnt take long to get used to that kind of power and when I get a spike those extra kiler wasps give me a woody and now I'm chasing 400awkw.... but I think i'll do a rebuild first :P
cheers
Yeah you're gonna get used to that power real quick as the chassis is just begging for more. As far as cats go, you could look at a ceramic one from CES, got one on mine but it's 350 bucks- trevor does a nice job with the taper pipework which keeps the boundary layer from separating from the walls and keeps the gas going through all the core. Pulled my magic cat with the shallow tapers off my previous ride and the whole centre had detached from the sides and was knocking around. Of course if you're heading CES way you'll want to check out his race dumps and front pipe which from experience bring boost on about 500rpm earlier and give a nice little extra push on the back. But a little hard on the wallet....
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
