you must understand also the associated time, overheads, risk, etc that has to be factored into dyno time. Anthony is charging $400 for a tune which in my opinion is way too cheap. Does QT do the timing map? or just the AFR's?
Yeah but thats to tune a power fc, I have done a complete Power FC remap in r33's which have had bigger injectors in less then a hour, have done sooo many of them I can get them knocked over in no time at all
new firmware is available. 4.2.3
ohhhhh santa has come early this year!!! I will be uploading that this weekend
  • Replies 155
ECU Firmware Release Notes
IMPORTANT
Please read this document carefully. It outlines new features and fixes for all released ECU Firmware versions. Make sure you understand these changes and take the necessary steps to check and initialise all new features.
After reading this document, close this window to continue with the firmware upgrade.
NOTE: DO NOT attempt a Firmware Upgrade within one day of a race meeting. Adequate time should be allowed to solve any problems that may arise.
ECU Firmware Updates and Fixes
WARNING: Once an ECU has been upgraded to V4.3.2 there is no going back to a previous version. Be sure to allow adequate time to set up new features and solve any problems that may arise.
Firmware Version 4.3.2– 1/12/08
Fixes
Rotary Trailing Ignition. With the Ignition selected to "Rotary - Leading Wasted" only the front trailing matched the split table. The rear trailing split always lagged 12 degrees behind.
Firmware Version 4.3.1– 26/11/08
New Features
Suzuki Swift VVTi trigger decoding added.
Firmware Version 4.3.0– 20/11/08
New Features
ECU on-board datalogging. Number of logged parameters is fixed with adjustable logging rate and activation method.
Wide Band Closed Loop Lambda using AFR Target Table.
Audi 5 Cylinder 135 tooth trigger decoding.
Key-On Speedo sweep function.
Baud Rate adjustable. 115200, 57600.
Password Protection.
Fixes
NB Closed Loop.
Temperature channels other than ECT and IAT showing incorrect values when in a fault state.
Ford BA XR6 Turbo Cam control.
Changes
You can now select the number of active Fuel Drives when Staged Group Injection selected.
Hey guys,
what are these vipec ecu's like compared to something like fcon pro? put the limitations aside with the fcon's "access to tuning software problem" and tell me what you think!
tho i guess this question would be hard to answer since not many people have looked at the fcon from a tuning point of view but surely someone would know :banana:
Cheers.
i will probably give the firmware a go this weekend also.
That frees up the narrow band analog input for your EGT sensor/s too Anthony.
yeah or my gizzmo k-mon :banana:
my car is now running the new firmware, the wideband closed loop is working though needs the fuel map to be much more accurate than the narrow band closed loop does or it is a bit slow to pull the AFR up (or i need to fiddle with the gain control more as i am currently using the same value for WB as i was on the narrow band)
nice... I aint game to upgrade firmware till i get to newcastle :blush:
Im running this ECU in my GTR and am extremely happy with its performance its definalty on par with the Haltech E11v2 i was using before. Just curious how much did the external map sensor cost? as im thinking of boosting my car abit more.
yay another line running vipec.i have had mine insalled for about 10/12 weeks and its been great.
Boost settings never give me any rob compared to my old ebc or manual boost controller
wont be long and i will be wanting another one in my HR30 running L20et
Its a rebranded Link computer by all accounts. Link of late have lifted their game substantially and make some pretty sharp ECU's.
I remember actually posting something suggesting re the new Link Ecu's in the tech forum a few months ago and being rubbished about the specs vs power fc etc. Its quite funny what a name change can achieve.
Glad your happy with your ecu mate. The one running in my car I cant fault as yet.
The plug-in boards are a TF electronics product, marketed and sold by Ray Hall (Vi-PEC) but yes they use the same chipset and tuning software as Link. The development of this product without TF's input would have seen the Link product not be at the standard it is today as TF did all the development on it. In effect the Link ecu is a re-branded Vi-PEC product, thats the reason why "link have lifted their game" as you put it. If it wasn't for TF's involvement the Link product would still be sub-standard.
has new firmware been removed from website ?
Titan, can you email it to me? [email protected]
Or was it removed for a reason? or am i missing something?
Hi Paul
It doesn't do timing, just AFRs.
I do understand your point re dyno time. I'm also trying to be as objective as possible, and not being critical in the least about either Vipec or the tuners who use it. However, if the product's own website, and the man who developed it, state that a full new new map can be done in 20min, and better than most tuners, then the tuning time and cost should be less than for a product that doesn't have the same functionality. I've always thought that's why people pay for functionality in a good product like Vipec in the first place.
If the cost of tuning doesn't change because despite the advantage of QT more time is required to utilise the extra features offered by the Vipec that would be understandable, but this is almost the opposite.
It's up to individuals what they do, but I'd welcome any logical explanation as to why a time saving function that the owner pays for shouldn't lower the cost of fuel mapping. Anyway...just my 2c, this thread is about Anthony's experiences.
Cheers
Trent, i soldered the Vi-PEC loom to one of Rays adapter boards so the V88 unit just plugs in....easy!
who are these available thru? ray or someone else?
Edited by Cartman
to be honest every product needs a gimmic to market (the autotune is no gimmic) and with the vipec they have chosen to that particular feature to spruke. I come from a marketing background (of late).
Auto tune is great but there is also the time needed to actually interface the wide band etc... which itself probaly takes more than 20mins the first time you hook it up.....
To me i pay for a product like the vipec as it has the resolution and computing power upgradabilty add on features etc... all thing required to do the job properly, to me the auto tune side of things is a add-on luxury that makes no real differrence to the ACTUAL ecu... what if microtech offerred the same autotune? i know i still would not buy one.... buy an ecu based on other parameters... of which the VIPEC / LINK has loads.
Edited by URAS
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
