just get a full kit from one of the sponsors
installing is easy just jack it up and get under it, undo all the bolts you can find then line up the new system and do up all the bolts you can find haha
+1 HKS all the way
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4340835
C.E.S very expensive for what they do.
I went to Rob Bliss for the same job at half the price.
I know what you mean
Trust is a bit of a rip off for turbos as well
so I went to ebay, and got myself turbo, manifold and wastegate for half the price
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4348902
:blush: That made me laugh!!!!
Yep I've got a CES system, pricey but performs beyond belief, and best of all legal dB
I'm glad I went there, a friend with an R34 tried to do it for cheaper and got all the parts from CES had someone else fit and weld it up and ended in disaster....the car actually ended up going to CES to have them fix up what had been done and tune the length of the exhaust to remove all of the excessive drone.
It's not just a matter of custom welding a bunch of pipes together, there's a lot more on the technical side to getting flow and low noise.
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4348944
A turbo and an exhaust is a bit different.
Its only my opinion on the decision i made at the time.
Not everyone has to spend thousands of dollars on an exhaust for a daily street car.
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4349477
Sorry to hijack thread, but I thought it best to post here than start a new one.
I'm getting my exhaust done next week as part of my turbo conversion.
At the moment I'm looking at getting the exhaust done at Right Price Exhaust since it's just down the street from Hi-Power Racing who are doing the conversion.
So far I've heard good things about Right Price, but I just want a second opinion before I go ahead with getting them to do it.
I've been advised that the turbo and JJR front/dump and cat will have to be fitted first and then the exhaust done so to make sure everything fits up right, and as such right price being close by is a logical choice as far as that goes. Is it worth looking at other options?
I've got the JJR Front/Dump pipe, just the cat converter and catback is what I'll need, so won't need a complete turboback made up.
Been quoted $510 for a 3" mandrel bent system with resonator and canon tip, or $590 for the same but with a oval barrel twin tip. Reaonable? Excessive?
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4357333
Thanks for the tip Dan, I'll take your word for it and go with Right Price, particularly since they've done it before. Didn't you get 2.75" though back then? Should I stick with 3" all the way? Still figuring out whether to go oval barrel twin tip, or a standard canon.
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4357669
The original exhaust on the other car was all from an R33 and modified to fit, had a funny 30cm hump near the firewall to clear everything...think it was about 2.75" with a round tip.
Yeah get 3" I've currently got a twin tip, it looks stock :)
https://www.sau.com.au/forums/topic/249393-exhaust/#findComment-4357719
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
