School Zone Camera @ 10:00pm?
eeiko321
 Share
As Fatz said, the signs are a courtesy and not a legal requirement. They are not a gazetted traffic sign in the road rules 2008 (However the speed limit symbol on the sign is). There is no excemption from a speeding offence in the Road Transport (Safety and Traffic Management) Act 1999 if signs arent present.
The only sign legally required to enforce a speed limit apart from the default 50km/h limit (Which requires no signage at all) Is a speed restriction or derestriction sign.
someone who who knoes the law
about farken time
well there is always exemptions dude...
just summon a court case and yell out to the judge "wulla i swear i wasnt speeding couz!, coz im a good driver but....!"
Hehe. Seen it tried in a few courts. Funnily often referred to as ignorance. Good to watch but ends like every other train smash, Horrifying but you just cant help but look. :santa:
If the matter is proven and you are dealt with by way of a S10 dismissal. If this is the case you can appeal to the RTA to get your points back.
If no prima facie is reached and the matter is dismissed then you retain your points
lol yea rta will give your point back :santa:
s10 means you admit to speeding but the judge lets you off casue you can speak without saying "youse should let me off!"
you dont get you points back for admiting to speeding
lol
im drunk its christmas drive safetly!
regarding points
it shits me this system
but oh well im gonna start a new thread on who has what points..........
  • 3 weeks later...
start of school they will be opperational
simple as that
has school started!!!????
work it out!
i dunno if your post was suppose to be sarcastic......
but if not.....
what we meant by up and running is that... weeks ago.....the 2nd part of the camera...(the smaller Lense) was missing with wires hanging out. and obviously it needs both larger and smaller lense box to work. so visually you can tell its not working.
but recently what i think people are telling us is that they have completed it physically by appearance.
but school hasnt started just yet.....
but the camera is NOT just a School Zone camera...it also works as a Standard Speed Camera depending on the time of day.
so in otherwords.....the other school zone cameras throught NSW currently STILL WORK.... but its just during the schedule during school hours.....since its holidays...it will be a normal speed camera at 60km/h.
so perhaps they got it up and running but obviously they shouldnt snap you at 60km during school times.
isnt woodvile rd 70?
yeah but i was refering to other speed cameras in sydney
mostly are 60km/h
that spot with the speed camera we were talking about....thats a pretty easy spot to go over the limit.
Even when they are signposted the RTA will generally have a lead in period where the camera is operational but infringement notices are not issued. This may run for up to 6 weeks and is part of the policy regarding public awareness when installing traffic enforcement cameras.
as i said before they will issued warning letters for teh first month when they are turned on
however if you go threw at 150 dont excpect to get a warning notice
yeah personally i wouldnt risk it at all......
even though the cameras looks very much FULLY operational...due to the fact both cameras are up and the 3 Warning signs towards the cameras are posted...
but the only thing is that the Electronic signs say "commencing soon"
either way i slow down just incase... i tend to think of the worst case scenario.
its not worth it if it just takes you 2 seconds to slow down at that point.
  • 4 weeks later...
 Share
    • Is WHC34 a 2 wheel drive Stagea?  4wd Stagea 100% fits, and I'd say 99% sure 2wd will too....they just used the GTR setup as that best suited the wagon floor. BTW I hope you saw Brett's post about potential reasons for a leak, unless you can see the plastic cracked somewhere, it is unlikely to be the tank itself leaking.  Can you see fuel dripping or is it just a smell when you park? Have you had any of the tank/pump holder apart?
    • They did get back to me. First response is from the mechanic that did the work. The problem is that the information that followed wasn't in the original report, which again, I let car inspect know should have been provided and influenced my decision to buy. Ball is back in their court and they have 5 more days to respond.  The actual structural damage was not a complete write off as they had me originally believe.  It just needed to be corrected properly and cleanly as opposed to the botch job of whoever did it last on the rad support and undercarriage. Smoothed out the scrappy welds and did it properly plus painted.
    • Haven't updated this is a while. -5 speed conversion is done. Then center console, parking brake handle, and mounting bracket can be adapted from a R34 since the S2 parts are all disco. Console is a slightly different grain pattern and color but works fine. R33/ R34 GTS (no booster) clutch pedal works as well as the matching master cylinder. Wiring is simple, jump the starter connector at the fuse box, note which wires are connected at which position on the auto neutral safety switch and cut off the switch harness and connect to the corresponding switch on the 5 speed. -Rear R34 rear subframe swap is completed. Full Nismo arm set, 2-way LSD set up soft, 322mm Brembo brakes, Ohlins Flag-R coil overs (need to drop the spring rate 1Kg) -RB swap is under way. HKS Step 2 High Response 2.8 BCD stroker kit / Step 2 V-Cam / GTIII 4R Kit I may not use the 4R kit but not sure yet as I've seen some pretty decent dyno sheets on it and it doesn't spool as slow as people think when you have v-cam. I have the wiring manual for the car and a spare 260RS harness so the wiring shouldn't be that bad but I just haven't had the time to invest in it. If anyone has a suggestion for someone who can handle it let me know! I have a bunch of spare 5mt swap parts and some Nismo 580 turbos if anyone needs/wants them hit me up. Located in California but willing to ship. As always, thanks to all the members who have answered my questions and helped this project keep moving!
    • Did Car Inspect get back to you? How bad was the actual "structural" damage? What front surgery was required?
    • I would be, however the last PS I owned was a PS1 and the last GT I played was GT1 lol. Also, how do you dads even have time to do anything? I barely have time to even sleep 7 hours a night!
