Hoping you guys on the forum might be able to help :cheers:
I have an R33 GTS-t series II 4 door manual. THe problem im having is whenever im in traffic and on and off the clutch, in a drive through or just getting in the driveway at home, the engine seems to nearly stall. Have cleaned AFM, recently fitted "cheap" dump pipe a HPI split front pipe. Any ideas on what could be causing this little gremlin would be a great help :P
https://www.sau.com.au/forums/topic/249978-damn-thing-nearly-cuts-out/
I think I know eactly how to fix the problem.
You car seems to have a problem where they made a mistake and put too many doors on it. Simply unbolt the rear doors, and weld plates over where they were, and all of your problems should go away.
lol.
Do you have an aftermarket blow off valve? If you do, then a lot of people here are going to kill you.
lol.
See know that could be the problem lol, but no, standard BOV, Trust Airinx air filter and hard pipe, Greddy 'cooler. Was almost thinking it could be coil packs, but does not miss when on boost (9psi low and 12psi high)
Thanks fellas!
Just picked up an aacv from Japanese Import spares as was surprised at the amount of crap that does collect in them. Gave it a good clean inside and out and will fit it tonight.
Also going to give the fuel pump hard wiring a go over the next few days too.
If thats doesn't fix the problem then i'll give the diagnostic a go.
Such a wealth of knowledge, thanks again :domokun:
I have the same problem in my 33 gts-t. Also every time i fuel up, it just cuts out straight away. But not so long ago i had to use 95 octane fuel because they ran out of 98 octane, and never had that problem. So i think the problem is also that because 98 octane fuel burns slower it is not making sufficient burning thats just my thought. But don't use 95 on a turbo car it can cause detonation - bad.
reset ur ecu
i had this problem after having an atmo bov on for a couple of days then putting the stock one back on. Car was still stalling and acting up on idle
ended up taking off and cleaning aac valve, cleaning afm, playing with tps did heaps of stuff then i just ended up resetting the ecu by unplugging the battery and pressing brake, turning lights etc on to drain all the power and then plugged it back in and ran perfect.
Some say u need to do more then that to reset the ecu so maybe a good idea to do what i did then leave it unplugged overnight
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
