  • Replies 2.5k
Posted Images
dammit. i was hoping for a hamilton style smoking for senna.
i got a hundred on hamilton not even making the top 3 in the WDC this year. too much pressure, too much expectation, too many other good drivers...
good bet i reckon, he nearly threw it away for the second year running if it wasnt for Glock moving over for him. Hamilton is yet to win a championship convinceingly. tough season to come for him.
Now they can go back to doing what they do best- being an engine supplier only
Instead of running a busted-arse race team
Either that or get the Richards/Willis combo running it again... Remember when J. Button was best of the rest in 2004? I'm sure these lads know how to run a team! Barichello/Senna & Button in a Prodrive Honda.... MMmmmmm! :)
Edited by Marco-R34GTT
I'd say the pressure is on him more than ever.. To win the championship convincingly... Loosing position to an inferior Toro Rosso a few laps from the end isn't all that convincing... I say that he drove wonderfully most of the season, and in China he drove as he needed to, level headed, aggressive and fast without going nucking futs.. Brazil on the other hand, he was off the boil, badly.. Then there was Japan... Red mist anyone???
his best has come and gone, time to get some new guys in
ah yeah, for sure- just thought you might have harboured some specific grudge against him
just like Webber, He'll certainly never have a WDC to his name
the v8s ran last year. it was the first time in a while but they were definately there. so id say there is a good chance of seeing the R35, they did a parade last year which had the Bugatti Vayron in it, should have heard that thing.
Are V8's on the schedule for Melbourne? They weren't last year!
Will be interesting to see how Kimi goes after his WC hang over last year, testing looking good already for the red team
Rubens proved he still had it... He out drove and out scored Button this year... Doesn't sound like much of a 'has-been' performance to me....
doesn't say much for Button, does it?
who are they both driving for respectively this year?
Lol, if glock didnt stay out on the wrong tyres he wouldnt have even been there for hamilton to pass easily on the right tyres
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
