yes, you need an invite?
Apparently so...I was a member all last season and some of 07, but when I tried to log in more recently it says incorrect username/password, so I tried the password recovery....Says my email isn't even on the database...
So yeah, if you can help me out with an invite that'd be great. :ermm:
  • Replies 2.5k
Posted Images
only live timing on formula one official site http://www.formula1.com/ f1 sign up 4 live timing get in lke less that 5min
underground racing do they have live streaming can ya just sign up or do ya need an invite? keen as for some live streaming as one is shit i was hoping for today to watch it on it but nothing.... sav man can i get an invite pleaz u need invite
No live streaming...Try this link...
http://formulanoticias.freehostia.com/index.html
after reading the radio conversation, I think charlie should go and disqualify himself. Seems the team wanted to do everything nice and proper yet he couldn't get any confirmation.....so Charlie GTFO, close the door on your way out.
And that quote came from where? Just a post on the previous page. :ermm:
Read this:
http://www.autosport.com/news/report.php/id/74153
After reading that interview, the interviewer should be disqualified from interviewing anyone ever again, and perhaps Whitmash could receive an award for not smacking him in the head.
But...
But...
But...
Not to mention asking the same question about 20 times and therefore getting the same answer 20 times with the words in a different order...
They cleaned out the database afew months ago of all the leechers.
Ah I see...Wasn't really able to seed on my old plan, but have more usage now so wouldn't be a problem
Someone hook me up with an invite :ermm:
Do you know if that link will work for future practice sessions?
I have no idea
from Hamilton
Straight after that we were requested by the stewards, and while waiting I was instructed and misled by my team manager to withhold information, and that is what I did.
"I sincerely apologise to the stewards for wasting their time. I’d like to say sorry to all my fans who have believed in me, and have supported me for years. I am not a liar or a dishonest person. I am a team player. Every time I have been informed to do something I have done it. This time I realise it was a huge mistake. I am learning from it. It has taken a huge toll on me.”
from Hamilton
Didn't he ignore team as they didn't benefit him in the past...When Alonso was at McLaren..?
he is a self acknowledged team player.
GO TEAM HAMILTON
(it's easy to be a team player when you are the beneficiary of every decision)
Edited by wolverine
old habits die hard, maybe Homo expected the toyotas to move over for him again.
GO TEAM HAMILTON
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
