  • Replies 2.5k
Posted Images
1. Giancarlo Fisichella, Force India, 648kg
2. Jarno Trulli, Toyota, 656.5
3. Nick Heidfeld, BMW Sauber, 655
4. Rubens Barrichello, Brawn GP, 644.5
5. Robert Kubica, BMW Sauber, 649
6. Kimi Raikkonen, Ferrari, 655
7. Timo Glock, Toyota, 648.5
8. Sebastian Vettel, Red Bull, 662.5
9. Mark Webber, Red Bull, 658
10. Nico Rosberg, Williams, 670
11. Adrian Sutil, Force India, 678.5
12. Lewis Hamilton, McLaren, 693.5
13. Fernando Alonso, Renault, 684.4
14. Jenson Button, Brawn GP, 694.2
15. Heikki Kovalainen, McLaren, 697
16. Sebastien Buemi, Toro Rosso, 685
17. Jaime Alguersuari, Toro Rosso, 704.5
18. Kazuki Nakajima, Williams, 706.1
19. Romain Grosjean, Renault, 704.7
20. Luca Badoer, Ferrari, 691.5
Yeh, i can see some caebag up front as ppl back themselves for a win. I thinl Trulli has to be favourite. I wonder if Kimi can get it off the line from where he is?
RBR may get some points bt another shocking weekend means that you have to say they are letting a great opportunity pass them by...ditto Brawn are choking and not performing
the BMW guys suddenly finding a lot of pace. no drive seems to motivate the non-event guys like it did with heikki last week.
All three of them dont deserve their seats, while guys like roseberg putt around in cars far below their talent level.
Oddly enough Rubens looks good for the double, its all over for button. he might still get the WDC, but wins look past him
This is the first time i am watchng a GP on a racetrack i have driven and it blows my mind the speeds they are doing through the corners and where they brake! I am such a hack, i want to go back to Spa now, i reckon i can cut 5s of lmy best time :)
And Webz in real trouble with Hamo just behind him. Can only hope that with some fresh blood backing themselves for a GP win up front that there is some carnage and 3-4 have trouble on the opening lap, inc Rubesn ... Shame i have to wish carnage on other drivers bt Webz needs a hand out :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
