hey guyz,
i got 200zr with old NICS rb20det, just wondering main differences between NICS and ECCS? i know turbo is diff but what bout injectors, afm and ECU?
I have an r32 turbo on atm but going the r33 route soon, just wonderin if this is straight bolt on yeh?
also canthe NICS version be epromed or even tuned thorugh ECU?
Also the stock boost controller has an electronic like solenoid connected to the vacuum piping to wastegate, can i wire in EBC around this?
any info much appreciated
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/
AFM & ECU different Injectors are same. the main Difference are the inlet manifold. the NICS has a 12 port inlet manifold the head is 6 port, there are two sets of runners on the NICS and only 6 on the ECCS, the theory on the NICS was that the two set of 6 runners are different length under low revs, or take off, the long ports are open giving more torque in theory. After the revs build up the second lot of runners are opened through the butterflys which are shorter for top end power. Turbo yes the RB25 bolts straight on, but you must get the banjos and oil lines as well. Next quetion the NICS chip is currently being worked on by a couple of people to see if it can be re-programmed so will have to wait and see.
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-531580
Originally posted by R32-GTS
THe injectors are different . Even on the red top. So get some first hand experience before correcting me.
well R31Heaven... be prepared to stand correct by the man with the expirirance :) :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-536105
Originally posted by rsx84
theres an old hpi mag that has all the ins and outs to do with the red top rb20 if you pm me if you still need info i'll scan it and send it to you.
if it's from a year or two back...
Or maybe longer.
I've got that one (about 5 copies of it :() R31Heaven i think i've showed you a copy of it long ago...
It doesnt really have a lot of stuff in it though.
rsx84, can you scan it and e-mail it to me?
[email protected]
I just wanna make sure i've got the same one.
thanks. ash
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-549146
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
