hey guyz,
i got 200zr with old NICS rb20det, just wondering main differences between NICS and ECCS? i know turbo is diff but what bout injectors, afm and ECU?
I have an r32 turbo on atm but going the r33 route soon, just wonderin if this is straight bolt on yeh?
also canthe NICS version be epromed or even tuned thorugh ECU?
Also the stock boost controller has an electronic like solenoid connected to the vacuum piping to wastegate, can i wire in EBC around this?
any info much appreciated
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/
AFM & ECU different Injectors are same. the main Difference are the inlet manifold. the NICS has a 12 port inlet manifold the head is 6 port, there are two sets of runners on the NICS and only 6 on the ECCS, the theory on the NICS was that the two set of 6 runners are different length under low revs, or take off, the long ports are open giving more torque in theory. After the revs build up the second lot of runners are opened through the butterflys which are shorter for top end power. Turbo yes the RB25 bolts straight on, but you must get the banjos and oil lines as well. Next quetion the NICS chip is currently being worked on by a couple of people to see if it can be re-programmed so will have to wait and see.
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-531580
Originally posted by R32-GTS
THe injectors are different . Even on the red top. So get some first hand experience before correcting me.
well R31Heaven... be prepared to stand correct by the man with the expirirance :) :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-536105
Originally posted by rsx84
theres an old hpi mag that has all the ins and outs to do with the red top rb20 if you pm me if you still need info i'll scan it and send it to you.
if it's from a year or two back...
Or maybe longer.
I've got that one (about 5 copies of it :() R31Heaven i think i've showed you a copy of it long ago...
It doesnt really have a lot of stuff in it though.
rsx84, can you scan it and e-mail it to me?
[email protected]
I just wanna make sure i've got the same one.
thanks. ash
https://www.sau.com.au/forums/topic/25015-rb20det-nics-info/#findComment-549146
