Hi all, the below table are the SPEC for the RB25DE, I have an auto NA 34 and would like to get some idea of the best, economical ways of getting about 150km at the wheels, open to suggestion and if possible please list the mod, cost and the installation cost. :thumbsup:
EngineModelRB25DETypeWater cooling DOHCDisplacement, cc2498TurboNoCylindersSerial 6, 24 ValveMax Horsepower, hp / rpm200 / 6000Max Torque, Nm / rpm255.0 / 4000Fuel SystemEGI (Electronic Gasoline Injection)Fuel TypeGasolineCompression Ratio10.0Bore * Stroke, mm86 x 71.7Fuel Consumption, l/100km9.4
https://www.sau.com.au/forums/topic/250316-na-tune/
If it has to be kept N/A do the following
RB30 bottom end
Cams/Headwork
Decked block to bring compression to 10.5:1 (or through piston selection)
Aftermarket ECU
2.5" Exhaust with highflow cat converters
Install and fabrication costs will vary from shop to shop, but $8K should see a very reliable and well built setup that loves to rev
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4337531
150rwkw/200rwhp out of an RB25DE is going to cost you.
Machine work (porting will have to be done and getting the compression up, 10.5:1 probably won't cut it, you should be trying for 11:1 - 11.5:1 for 2.5lt and costs for big cams also)
About - $4000
Aftermarket ECU - Min $1000 then to wire in and tune another $1000
Decent Extractors - $1000
Labour - min $1000
Cams and springs - $1500
Oil an water pumps - $500
Exhaust piping - $750
Lightened Flywheel and new clutch - $1000
So about 11G should net a figure around 150rwkw probably 160 - 170rwkw, but in saying that people would say you spent all that money and get such a tiny power figure, but really that setup would be good for a mid - high 12 to low 13 sec quarter pass which isn't slow for an N/a
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4338468
12 second quarters would be asking way, way too much from 160rwkw on a 34. My mate has a Del Sol CRX (non turbo worked to the shit) with 171rwkw and he cuts 12.1 sec quarters, and his car is light as shit compared to the weight of a 34.
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4339214
About - $4000
Labour - min $1000
Wow that is a shit load, you might aswell sell and get a GTT, and even with money remaining, do some supporting mods and hit some good figures i guess!
MRXTCZ
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4340228
no they are not the same. RB25DE = high compression RB25DET = low compression. The low compression is made up for by boost via the turbo.
http://www.skylinesaustralia.com/forums/Rb...l&p=4306941
Simply bolting on a turbo to the RB25DE will not run properly and kill it very quickly. An RB25DE+t can be done though with the right parts, the right engine management that can handle fuel and ignition timing, and good tuning, and of course supporting mods such as fuel pump and injectors to meet the new demands, and of course keeping the boost level at a safe limit.
The hardest part is going to be whether you can do the labour, or paying a workshop to do it, and of course finding a workshop who will not only do the labour but will be willing to tune it. A fair few workshops refused to do it, or refused to tune such a set up. If you do it, make sure the tuner is confident with it.
I think it will be wise for you to have a read through the How To Turbo N/A Skyline thread. What I said above is a very very condensed version. It will also be good to look at the differences between an RB25DE and RB25DET engine.
http://www.skylinesaustralia.com/forums/tu...N-A-t33407.html
In regards to an LS1, this has been done on a number of S13's and a quick google shows that there's R34's that have had the LS1 treatment. There was a 320kw LS1 powered S13 in HPI Magazine issue 83.
Could always do a twin turbo LS1 :(
http://www.ls1.com.au/forum/showthread.php?t=61035
http://videos.streetfire.net/video/Nissan-...1-V8_169208.htm
http://videos.streetfire.net/video/Nissan-...-with_95344.htm
https://www.sau.com.au/forums/topic/250316-na-tune/#findComment-4341022
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
