Hello
I am wondering how to hook up an adjustable fuel pressure reg. I know that it goes on the return line just after the std one. But i was wondering do people just pull the vac line off the std one? or do they remove it all together?
It an R33
And there is another thing on the return line too, Is that another reg? or one way valve?
do you have a valid reason as to why you are installing one? If you are just putting one on for the hell of it then don't even worry about it. Put your shiny new one on ebay and sell it.
I'm running 300rwkw+ and still use a factory regulator.
If you put this on, prepare for your car to run like shit or unpredictable.
Edited by The Mafia
dont worry about mafia shotter, he has been spewing his "awesomeness" since 2003.
YES, use the vac source from the stock reg.
however why would u use 2 fpr's?
what type of fpr do u have, ie nismo?
I have a SARD one. And the guy thats going to tune my car said we can put it on there to raise the pressure a bit because i wont be changing the injectors yet. But as far as i know the std one is connected to the fuel rail so i cant really remove it.
Hmm. It took me 6 years to make 2,200 posts.
You, 1.5 years to make 1600 posts.
Lets do some maths:
Me = 1.6 posts per day.
R33Dickhead= 3 post per day.
Plus, you managed to post almost as much as me in just over a year, that it took me 6 years. Oh, and most of your posts are useless horseshit that is not worth reading.
You should go back to installing a Shiny noisy poofter blow off valve to your car, and a big fuel pressure regulator that can support 1000 horsepower. Would go well with that bulk of power you are making.
The points I were getting at is (there is more than one now)
1. If you aren't making more than 200rwkw, you don't need a FPR.
2. R33cruiser talks shit and should be banned from the forced induction section, and joined to the ricer bolt shiny thing on dickhead forum called www.nissansilva.com
Anyway, if you would like some further insight, just let me know. THe only insight you'll get from R33cruiser is the insight from the inside of his ass, as thats where his head is.
Edited by The Mafia
Careful with the sard one, most cars i Have tuned with sard ones I have had to pull them off due to regulation problems. They were all over tne shop with AFRs and proved useless to tune. Same deal with Malpassi.
Just curious, what are you mods?
If you are still running the standard turbo, then that will max out before the Injectors will, they usually hit 95% duty cycle at about 230rwkw - 240rwkw.
But anyway, a mod listing will be good.
Also, your original question - yes, you need a vac line on the FPR, as it also supplies boost to it, and will raise the pressure for every psi of boost it sees. The Factory FPR gives one extra PSI of fuel for every extra PSI of boost is sees. THe base pressure for a R33 is 43psi.
Edited by The Mafia
The last dyno run i had done was 210rwkw at 10psi. The car has a front mount intercooler, the turbo has been rebuilt, made bigger and the ceramic wheel replace with a steel one. fuel pump replace with a 023, 2 stage electronic boost controller. basically my tuner said it is possable to push more power out of the std injectors by raising the fuel pressure. and i thought i could hook it up before i get there so i dont have to waste money on him doing it. Can someone tell me what else is on the return line. There is a right angle fitting about a foot down from the std fuel reg. What does this do? it kinda looks like another fuel reg just without the vac line fitting.
Lets do some maths:
F***ing SNAP!!!!
Lol. But Mafia is right, FPR's on basically stock cars trying to "squeeze" extra power out of the stock injectors by bumping up the fuel pressure isn't the best idea and isn't highly recommended. Get yourself some cheap second hand S15 injectors if you only want a little bit more headroom from your injectors.
I plan to get bigger injectors in the future but for the moment im thinking about just putting in the adj fuel reg and seeing what it can do. Can anyone tell me what the right angle fitting thing is thats on the return line?
sorry mate, I haven't changed one before so I have told you all that I can tell you.
I'm sure there is someone that has done it before.
Just remember you can push the stock injectors to almost 240rwkw. Won't that be enough? I don't recommend pushing too muc more out of them, one might beak and cause a catastropic failure.
It is the std one but it has been rebuilt, borred out and the ceramic wheel has been replaced with a steel one. Some company rebuilds them and does all of this. I think it is now rated at 450hp but im not sure. It was done before i bought the car.
well there is a thread I wrote, about making 300rwkws.
I used a GT3037 turbo. NIce little unit, not laggy either.
Do a search for "My 300rwkw adventures" and put me as the member. It should pop up and give you everything you will need.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
