well i have just put a s2 rb25det into my 1993 r32 gtst...
mods:
apexi turbo
z32
power fc
splitfires
nismo 555cc
metal intake pipe with BOV return lines removed.
3inch turbo back
eboost
fmic
catch can
now it has been tuned abd makes 250rwkw on 15psi.
everytime i clutch in the revs die and the car turns off..
we pressure tested the whole system and found a leaking plenum gasket so replaced that and still stalling.
there are no other leaks in piping etc..
any ideas on what i can look out for?
cheers
https://www.sau.com.au/forums/topic/250773-r32-rb25det-keeps-stalling/
yeh my stock BOV is blocked off..
and the bov return lines removed and a single metal intake pipe made up!
should i put the stock intake pipe in with the return lines and c how we go?
well, when I blocked up my stock BOV the car started stalling as if i had vent to atmosphere one on.
I couldn't fit it. Was really weird, so I just installed the stock one (with return line) on again and its fine.
  • 6 months later...
  • 1 month later...
I would say it would be the power fc. First of all what power fc are you using (d-jetro?) seeing as you have a afm im guessing you have the older one. I have a similar problem with mine. Atm making 400hp with the pfc and it drops idle alot when i put clutch in but doesnt stall. Any ive been told its coz of the pfc running a afm. Recommended to change the ecu or maybe try move afm a bit further from turbo as this will decrease the back pressure that the turbo gives off when you come off throttle.
??? If it is the afm that's causing the stall than infact it would be. As the older version doesnt not have a map and relys on the data from the afm to keep the engine idling correctly. That's y the d-jetro version and all dont run the afm anymore due to this issue of back pressure and the pfc stalling the engine.
Ok believe me or not - im telling you it is not the ECU.
l-jetro and d-jetro are two different versions - one does not superseed the other.
What you were told, was wrong. I've run AFM's on 370rwkw setups, no idle/stalling or otherwise if your tuner actually has a clue
Sounds like you were fed b/s just to have a new ECU put in due to either the tuner making money, or to hide the fact they do not know what to do.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
