  • Replies 124
Im not sure. The only thing he said was something about the ECU going back to the battery and not the alternator. The only problem i have is if i winge too much he could easily change a few figures in the ecu and either detune it, or make it a time bomb waiting to happen. I think this time as times in the past when i have been burnt by workshops is to just pay it and never go there again.
Here is the dyno sheets that $1000 of tuning got me.
And it's only running 12psi. They said they pushed the boost up but it didn't make much more power. Does this sound like B/S? The engine has forgies in it and the turbo is bigger than stock with a steel wheel. I have pushed it to 16 psi and it felt like it had much more power than 12psi. And i dont know where they pulled the 168.9kw run out off. it was making 200kw when i got there... The usuall tricks to make the figures look better. So please people that see dyno sheets all the time please tell me what you think about these.
best to list the parts you've got in there and what tune you're running on.
It's one of those things where I think the workshop will be able to justify the bill because of the amount of time spent on your car. But that's why the advice has been to take it to another workshop, because these guys may lack the experience. It could be that they took 5 hours to find a problem that would take another workshop 1 hour. So best to part ways me thinks.
Yea i will NEVER EVER go back to these muppets. I do understand that time is money and yea they could justify there time and the cost. The thing that has pissed me off the most is there was no communication!!! They kept telling me that they will look after me and that it wont cost much at all.
The mods are FMIC, electronic boost controller, turbo has been rebuilt and made bigger and a steel wheel. I think it's rated at 450hp now. bigger fuel pump, haltech interceptor. engine rebuilt with forgies.
Well i paid the bill and picked up the car. So pissed off at the company. But i have to admit the car does run well. Not $2200 worth but it is good. And i found out that dyno time was charged at around $235 and hour
So $235 per hr and they couldnt even find that it had a bad earth proplem???
Do any of you boy's/girl's get pre dyno check's done before your tune???
We do battery, power to coil, power to fuel pump and fuel flow/pressure check's before every run and add it into the bill.
Best to sort these issue's out before you waste 20-30min's to strap it down and end up with no result.
Bet there isnt a person on this site who would not have wasted days trying to find that problem. How many people who have a car that suddenly drops 150kw have a first thorght of "I wonder if the the battery terminal did it"???? The guy probably didnt charge you for half the time he wasted on it trying to diagnose someones else's substandard work. Dont forget that you now have a car that is running sweet and has had everthing on it checked and double checked. Regardless of wether you planned to spent that money or not its not wasted!! Another point to remember is if you change workshops now there is a real good chance that the first time you have a problem your NEW!! workshop will be charging you AGAIN!! to check things that you just paid this guy to do. He on the other hand will be know your car very well. No I do not have a workshop and dont know the car or the workshop from this thread. Just my two cents on a subject where it seems that most of the advise given to you is based on other people knowing everthing and your mechanic supposedly knowing nothing. Niether of these two things are true so try not to judge too unfairly.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
