Do you have the bigger Nismo slave cylinder?
You dont need to use a Nismo slave cylinder.
I just whacked on a Nismo Super Coppermix Twin on my car and so far it's been a very positive upgrade. I'm surprised at how easy it is to control. I thought it would be more like a button type clutch which I've used before and gave me the shits in traffic. It grabs / bites harder than the stock clutch but still feels easy to handle. And you can definitely launch better and quicker than stock unit. I dig the rattling sound, it makes the car feel more raw and tough!
Edited by mxfly
I'll answer your questions.
Thanks for your reply. I do have some follow up questions:
1) How long have you had the NISMO twin plate clutch for? I ask this because I am wondering approx. how long this particular clutch lasts? (Obviously depending on driving..) A clutch can last you years, just depending on how hard to use it.
2) Did you have to replace anything else when you swapped over to the nismo clutch? ie - thrust bearings, pivot forks etc??? New thrust bearing is provided with the kit.
3) So your nismo clutch does allow a little bit of slip? ie - not like your either on or off? There's slip so it's easier to ride it. But there's also enough bite as well.
4) Is the pedal feeling a lot heavier than stock? Does feels heavier than stock but it's not that bad.
5) If you were to sum it up, would you say that the nismo twin plate is easy to drive? 1000%!
6) Finally would you recomend getting the NISMO big operating slave cylinder? Using a Nismo cylinder would make it feel like stock. In fact it feels lighter than stock when i tried it out on another car.
  • 4 months later...
Hi guys, I'm about to fork out and upgrade my clutch. I'm leaning towards the Nismo Super Coppermix twin plate kit (640ps), however I've been advised by some that there have been reliabilty issues in them slipping at lower power levels? Can anyone comment?
Also, Sliding Performance stock these:
ORC Single Plate clutch kit ORC 409D-01N (400ps) (Includes flywheel), $1489
, which are a single plate option (assuming also for GTR application) including light weight flywheel and are half the cost of a twin plate kit. Has anybody had experience with these ORC single plate kits (or any other) single plate clutch kits on an R34 GTR? Pro's and con's?
I'll be running approx. 360hp @ the wheels.
Cheers,
Ed
  • 5 months later...
Hi Guys
Im using the HKS Twins on a 34GTT, in traffic you need patience to understand it's ON/OFF habit. Don't let anyone drive it if they are not familiar with it, but one thing makes me wanna keep it is the launch effect and every gear change bite i get on every gear. Im on my second set now, thought of changing to the ORC or Exedy Hyper Single because the traffic situation is getting unbearable. Nismo Coppermix is pricey so that option is out. My target is 400-450hp clutch set that can drive easily for me (or my other half). Which one would you guys recommend?
Mate, I've got an R34 GTR as well and I recently replaced my clutch with a Jim Berry Full Monty Item. Cost about $1700 - 1800 delivered and he said it can hold upto 700hp. My car just got a pair of -5's but hasn't been tuned yet so I can't tell you how it handles a reasonable bit of power. I too am after 300-350awkw and I explained this to Jim at the time and he assured me that this clutch will handle those numbers without a problem. Also advised me that they're quite cheap to rebuild, he can rebuild one of his own clutches for $400-500. The car is my daily driver and the clutch is very driveable, worth a thought instead of the jap brands anyway mate...
  • 2 months later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
