problem been discussed a lot on sau, its common on all r32's to need a blip of the throttle to stop it stalling.
Unfortunately no one has found a solution to this problem :D
When i put in a brand new heavy duty battery it would crank and idle with no throttle, but over the weeks it went back to its stalling.
A possibly solution is to clean the cold air regulator which lets in more air on cold starts. Perhaps this could be getting stuck and causing the stalling;
http://www.skylinesaustralia.com/forums/Ai...amp;hl=cold+air
Also doesnt hurt to clean the AAC valve too;
http://www.skylinesaustralia.com/forums/Di...html&hl=aac
Let us know how it goes ;)
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4345651
ive cleaned the AAC and AFM , there is a noticeable difference after cleaning it. if you haven't do so , i highly suggest you to do that first.
wanna do mine? <3 :)
How is your battery? You might have a weak battery, try recharging overnight and see how it goes.
When i put in a brand new battery it cranked once and jumped to life, but now its gone away :)
Also, when i first purchased the car it had no cold-start issues, it gradually happened after driving the car, so something must have worn out/clogged up during that time..
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347171
is yours RB20?
hmm battery seems fine , then again it came with the car ,ill check that next.
and yea it gradually happened
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347204
notice something funny, if i prime the fuel pump before cracking the engine, it most likely gonna have a hard cold start (rev below 700rpm)
HOWEVER, if i start the key straight away without waiting, the car actually starts at first go (rev stays at 7-800rpm bout 1-2 sec and its back to normal 1100-1200 rpm)
but still a tiny bit hesitation but no where near as bad as before.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347894
Mine starts strangely in the morning also, turn the key and it fires up nicely. Revs drop to almost a stall, tap the throttle and up it goes to about 2 grand for a while. Strange yes! Done anything about it, no! :D
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4351294
Here's a video of my starting which i recorded over a year ago. Sounds similar to yours AdMan
I always have to blip the throttle when starting or it stalls, i tend to blip the throttle into any other car i jump into because of this haha
Im putting in cleaned gtr injectors soon and getting a tune, will see if it will fix the problem.
Also, not sure if it helps, but after i installed a gtr fuel pump, the cold start actually got worse..ho hum
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4351533
Definately clean your cold air regulator. It's a bit of a bitch to get to but it worked for me.
Had the same cold start problem as you. Turns out the regulator was stuck open, pulled it out and cleaned it and now it starts nicely - no throttle needed.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354358
Hi there, I have had this issue for years now, I had the injectors cleaned, new temp sensor, cleaned the AAC valve and really didn't see that much of difference. One thing I did change which helped a lot was one of the Fuses that goes to the ECU, this made the most noticeable difference but didn't cure the issue. Does anyone have pics of what the Cold Air Reg looks like on a 33? Just want to have a look because it might be worth a crack.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354565
^^what he said..
which fuse are you referring to?
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354568
Check out this thread for some pics of the cold air reg: http://www.skylinesaustralia.com/forums/Fi...ob-t174735.html
Seems like it's even harder to get at than in the RB20...
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4355945
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
