i have recently run a big end on my 26 and because i am a cheap bastard, i have decided to bin the 26 bottom end and replace it with a 30. i was not planing on changing anything but have noticed that there is only one oil return hole in the sump and the 26 has two, one for each turbo, should i bother drill and tapping another one into the sump, or maybe installing a 't' into the 30 drain hole and run both oil return lines into it, or just buy a single turbo inlet manifold and a turbo and do away with the twins.
if i go single, what turbos have people used, i would rather a bit more mid range, than a big punch at the end.
will the standard n1 twin 26 turbos run out of puff in the high rev range?
any input will be greatly appreciated, thank you.
Edited by brada31ke70
https://www.sau.com.au/forums/topic/250923-twin-26-turbos-on-a-30/
If running a standard RB30 bottom end, I'd suggest spinning it to only about 7000RPM. 7500RPM max.
The N1 turbos flow enough to make 320 odd AWKW on a 26, drop boost a few PSi, and with lower rev limit you'll make "less" power, but you should pull the same torque. hence, a less stressed engine.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
