This might be one for the DIY
Power steering
Problem: If the power steering seems to be switching on and off while you are turning the wheel.
If you have no fluid loss and your belts are on and tight check the little universal that connects the rack to the steering shaft.
post-25786-1230975638_thumb.jpgpost-25786-1230975912_thumb.jpg Cost about $35.00
To fix
Undo the two bolts holding it on. Slide it up first to get it off the rack then pull it down. You may need to spread it slightly with a screwdriver but don’t get to aggressive.
Using a bolt and a socket in the vice (see photo) it is quite easy to push the old unit out. But be sure to put a piece of metal between the fingers of the universal (If these get bent it’s all over red rover) so as not to push them together. I used a piece of 3mm plate about 30mm long and about 25mm wide.
To install the new one you will need to take the caps off the star so you can insert it in to the fork then it is back to the vice.
It’s a little tricky at this point and it is easier if there is an extra pair of hands to hold everything while you do up the vice (Again with the piece of metal between the forks). Push the cups in far enough so the seals do their job. The cups should be about 1.5/2 mm below the surface. Give it a light tap with a centre pop punch and it should be as good as new.
https://www.sau.com.au/forums/topic/250961-power-steering/
Power steering
To fix
Undo the two bolts holding it on. Slide it up first to get it off the rack then pull it down. You may need to spread it slightly with a screwdriver but don't get to aggressive.
Using a bolt and a socket in the vice (see photo) it is quite easy to push the old unit out. But be sure to put a piece of metal between the fingers of the universal (If these get bent it's all over red rover) so as not to push them together. I used a piece of 3mm plate about 30mm long and about 25mm wide.
It's a little tricky at this point and it is easier if there is an extra pair of hands to hold everything while you do up the vice (Again with the piece of metal between the forks). Push the cups in far enough so the seals do their job. The cups should be about 1.5/2 mm below the surface. Give it a light tap with a centre pop punch and it should be as good as new.
Thanks for that. Were there any other clues such as sloppiness at the steering wheel or strange noises?
https://www.sau.com.au/forums/topic/250961-power-steering/#findComment-4346236
Hi
There was no noise or sloppiness at all. The only other noticeable thing was the colder it was IE first thing in the morning it would be more noticeable. It’s the two cups across one plane of the star that causes this feeling.
The process of elimination was as follows
1. Flush the system. Pedders did this for me at a cost of $125.oo which should be done on a regular basis according to them. The oil was very dirty. This did not fix the problem
2.2nd hand pump $110.oo. still not right
3.2nd hand rack $220.oo. problem still there
4.Universal joint $35.oo. 2hrs work and all is well again
So if anyone has the same symptoms this hopefully will save you some time and money.
phil
https://www.sau.com.au/forums/topic/250961-power-steering/#findComment-4347746
Hi
phil
thanks for the info im sure you will save someone else some good dollars regards mike .
https://www.sau.com.au/forums/topic/250961-power-steering/#findComment-4349220
Phil, thats a F lot of money to spend. Mine has a little "kick kick" some times. Maybe this could be the start of the prob. I'll keep an eye on it.
If it's not I know where I can lay my hands on a good 2nd hand pump and rack. LOL :rofl:
https://www.sau.com.au/forums/topic/250961-power-steering/#findComment-4349873
  • 1 year later...
Digging up an old thread... I know... but mine has done this for the ~3 years I have owned it; symptoms are park at ~3/4 lock and apply a slight turning force to the wheel and you can feel the assistance take the wheel and then let go sporadically.
https://www.sau.com.au/forums/topic/250961-power-steering/#findComment-5600392
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
