Which wires??
Guest RedLineGTR
Got a r33gtst...
does anyone know which wires that come from the steering wheel coloum are the ones for the headlights??
i want to attach a guages power to it so when my lights are on so is it. Which colour are the wires etc...
Or what would be a better place to connect it. Since the power cable from it is shortish..i would have to extend it abit to reach alot futher.
Cheers Rob
https://www.sau.com.au/forums/topic/25113-which-wires/
There should be a wire going to the potentiometer on the dimmer that will read +12V as soon as you flick the lights on. I think this is where i spliced my boost guage into.
Multimeter is your friend, even a cheap one for 10 bucks will do enough to let you know whats going on.
Red17
https://www.sau.com.au/forums/topic/25113-which-wires/#findComment-533832
just hook it on the back of the cluster, find the light gobes that light it up and solder u r wire on the printed circuit it will have power on when u have u r lights on and it will dim with the lights as well .
https://www.sau.com.au/forums/topic/25113-which-wires/#findComment-533910
Originally posted by RedLineGTR
With the compliance dimmer control..does it only ajust the dash with the speed and rpm etc..or does it ajust the other light buttons like hazard lights ac control lights etc.. can anyone help out
I believe it should only dim the backlights. Any warning or indication lights should be unaffected ie indicators, handbrake, etc
https://www.sau.com.au/forums/topic/25113-which-wires/#findComment-535247
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
