just wanna know what the go is with t3/t4 turbos on rb25's
i got a r34 gtt rb25neo
was wondering if anone has put a t3/t4 on a rb25 and what mods they had and wat power they got form it
i have onyl heard one bad thing about the tubro and that is that they may have lag issues.
but if it hauls ass in high then id ont care. :D
so let me know
https://www.sau.com.au/forums/topic/251337-t3t4/
hey check this out, i reckon it suits u well
http://au.youtube.com/watch?v=ag4nLpu1nJ0&...feature=related
that was a joke ^^
HKS gt-rs are good for that power range , other then that mayb highflowd rb25 or rb30 factory turbo or a AVO or IHI turbo, there pretty good too.
Edited by NISMØ
https://www.sau.com.au/forums/topic/251337-t3t4/#findComment-4358643
i jsut want a good turbo that will allow me to go to 250atw with mostly stock parts.
stock turbo only takes 12psi. and i want more!
Please try searching then.
There are pages and pages, threads upon threads about 250rwkw... how to get there, what you need and so on.
A good start is the FI Guide, and the Dyno Result threads, its what they were made for afterall
Thanks
https://www.sau.com.au/forums/topic/251337-t3t4/#findComment-4358672
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
