RDA Rotors group buys is back. All discounted GB prices will be quoted to you via pm and is for your eyes only, as RDA also need to protect the interests of their authorised dealers/retailers. For those who are new to this Group Buy, please click the link on my signature to see previous Group Buys and the tremendous response they generated since 2006-2008.
There are two types of rotors on offer as below:
Standard Slotted Rotors
Grooved Dimpled (Dimpled & Slots) - Gold Passivated - more rust resistance
More info can be found here: RDA Brakes Products
The following are the parts which I can get access to for most Nissans:
Sloted Rotors:
1. R32 GTS-t/Z32 300ZXTT: F=909S 280mm RRP $170, R=908S 297mm RRP $190 (Front can be used for S15 Silvias)
2. R32 GTR (early models): F=7926S 296mm RRP $305, R=908S 297mm RRP $190
3. R33 GTS-t/R34 GT non turbo: F=7693S 296mm RRP $305, R=908S 297mm RRP $190
4. R32 GTR (late model)/R33 GTR/R34 GTR: F=7701S 324mm RRP $355, R=7702S 300mm RRP $355
5. S14/S15 Silvia: F=909S 280mm RRP $170, R=906S RRP $165
6. R34 GT-T turbo: F=7957S 310mm RRP $355, R=908S 297mm RRP $190
7. V35 Skyline / 350Z touring non-brembo: F=954S 296mm $POA, R=7657S 292mm $POA
Grooved & Dimpled Rotors:
8. R32 GTS-t/Z32 300ZXTT: F=909G 280mm RRP $305, R=908G 297mm RRP $285 (Front can be used for S15 Silvias)
9. R32 GTR (early models): F=7926G 296mm RRP $440, R=908G 297mm RRP $285
10. R33 GTS-t/R34 GT non turbo: F=7693G 296mm RRP $465, R=908G 297mm RRP $285
11. R32 GTR (late model)/R33 GTR/R34 GTR: F=7701G 324mm RRP $575, R=7702G 300mm RRP $525
12. S14/S15 Silvia: F=909G 280mm RRP $305, R=906G RRP $285
13. R34 GT-T turbo: F=7957G 310mm RRP $465, R=908G 297mm RRP $285
14. V35 Skyline / 350Z touring non-brembo: F=954G 296mm $POA, R=7657G 292mm $POA
15. V35 Skyline / 350Z track BREMBO: ONLY AVAILABLE AS EBC GROOVED F=GD7122 324mm $POA, R=GD7123 322mm $POA
Can also get rotors for the following cars:
- S13 CA18DET/SR20DET
- R33 GTS non-turbo
*) All RRP prices above are per pair, GST inclusive however they DO NOT INCLUDE delivery costs.
In addition to rotors, I am now officially offering EBC Green/Red/Yellow pads to suit most Nissan cars above. Please pm me for quote.
Deliveries all around Aust in approximately 5-10 business days via road courier (organised by RDA). No pickups available as they'd rather send everything out to keep it simple rather than mocking around with orders and separating pickup and deliveries.
https://www.sau.com.au/forums/topic/251349-rda-rotors-ebc-pads-group-buy-2009/
  • Replies 447
Group buy prices are lower than what's posted in the 1st post above (RRP). those posted prices above are still exactly the same with the 2008 thread. For special group buy price go with the lower prices that's quoted through your pm...
How can i upgrade the rotors in my R34 25GT ?
I need slotted rotors.
Will the GTT ones fit ?
MRXTCZ
Unfortunately there were a few R34 NA owners who came up with different rotor size on their car, so we still unsure which ones will fit at the moment, until someone have a spare R34 NA rotors and can measure the diameter, inside hub diameter, inside hub depth, and other measurements, etc. Oh, and of course if it's coming from an R34 NA coupe or sedan and if sedan is it a GT, GTX or something else?
Are the 34 GTT rotors still reground GTR rotors or are they producing proper one to suit a R34 GTT?
Not anymore, they have a proper part number now. See first post:
and
Sorry, I shouldn't ask stupid questions late at night. All clear now.
Slotted Rotors:
Had a slight mistake, Groovies RRP price for R34 GTT front 7957G should be $575 = 7701G, not $465.
Same with Slotted 7957S = 7701S price
GB price of course is a lot lower than $575
Update to Batch 42 orders:
- TokyoTaxi (payment cleared)
- blk180 (payment cleared)
- zZzDanzZz (waiting for payment to clear)
- bigbadbob (waiting for payment to clear)
Mines a 25GT Coupe..
So what sort of measurements do you need.
List them out exactly.. and i;ll see what i can do.
MRXTCZ
Hey i helped with the sizes for the gtt im not sure if these will be wats needed fully but if u look at this link on page 10, post 199 u will see wat i done 2 help with the sizes. Hope this helps with getting u rotors. http://www.skylinesaustralia.com/forums/Rd...html&st=180
Thank's David. That was the GTT (turbo), what we need now is from R34 GT (non turbo)
MRXTCZ, if you can get me measurement (preferrablel all in mm):
Measure for your front rotors (R34 NA non turbo)
1) Rotor overall diameter
2) Rotor thickness
3) Rotor hat height (you can measure this from where the hub's hat meet the disc rotor surface, and adding the rotor thickness will give you the total rotor hat height)
4) Centre hole diameter of the rotor's hat (i believe all Nissan will be 68mm)
5) turn the rotor over, and measure the inside hub hole diameter
Do the same measure 1-5 above on your rear rotors (R34 Na non turbo)
See picture attached below, if anyone can do it I will take this forward...
You can save the picture, add your annotations to it and send it back to me via pm or post it here. Also don't forget to mention if your R34 GT NA is a sedan, coupe. Based on what people has told me, I am expecting to see different size for coupe and sedan, and potentially 2 different sizes for sedan depending on the grade... which is why it's getting a bit confusing...
PS: also include mention if your front and/or rear rotor is ventilated or solid disc
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
