  • Replies 447
it was arranged straight from RDA. They use either TNT road express or AAE couriers, or any other. Could be either one... I'm not sure what they use these days.
pm me for quote what you need. I've sent you a quote on 6th January, check your inbox
yea thanks for that but i didnt end up getting new r34 calipers to suit. but you still didnt answer my question about ebc pads in that PM
i will try again.
Update Group Buy #43 (closing 25th Feb)
- sheng (payment received)
- russky (waiting for payment to clear)
- ogz007 (waiting for payment to clear)
Nope, however Al did somewhat similar brake line group buy from Maltech, a company in Geelong who produces good ADR approved braided brake lines. I'm not sure if it's still on or not... http://www.maltech.com.au/
- sheng (payment cleared)
- russky (payment cleared)
- ogz007 (payment cleared)
All 3 payments have cleared.
Quote sent.
- JonnoHR31 (payment cleared)
All 4 payments have cleared
Quote sent.
- Angelecles (waiting for payment to clear)
- Angelecles (payment cleared)
All 5 payments cleared...
