How thick is your overall rear rotor diameter? according to RDA's catalogue, the rear R33 non turbo has an 8mm rear rotor thickness, being so thin, it is usually made as solid disc. There were a few ppl bought RDA7692 with 8mm thickness and it fits ok to rear R33 non turbo...
  • Replies 447
rotors on car are 15mm thick, supplied rotors are 10mm thick (there 8mm on the end due to a 1mm tapered lip on each side)
so 5mm thickness difference
ps all other dimensions are identical though
That must be because the old RDA7690 is no longer in production... that was 15mm thick, and was officially for a R32 GTS.
RDA catalogue only have RDA7692 listed that will fit within your rear caliper... 15mm vs 10mm is only about 2.5mm less on each side
so should be no problems... there were a few other R33 non turbo owners who bought RDA7692 previously and they didn't have problems fitting them on. if you do, let me know.
Cheers, Rianto
quote sent....
Group buy 44 update:
- nightcrawler (payment cleared)
- mccready (payment cleared)
- tteerrryy (payment cleared)
all 3 payments cleared
quote sent....
- runnin4life (waiting for payment to clear)
- -slide- (waiting for payment to clear)
- runnin4life (payment cleared)
- -slide- (payment cleared)
All 5 payments cleared
- Dohmar (waiting for payment to clear)
closing this weekend!
Got your order...
- Delta Force (waiting for payment to clear)
possibly a stupid question... but can you oversize the rotors and order GTR's one for a GTT?? or do you need bigger calipers to match?
the rear discs on my car (standard) just look pretty damn small...
no it's not stupid question.
it is possible, but the onus lies on you to fabricate or get someone to fabricate caliper adapter or finding an adapter to suit. mind that R34 GTT rotor's hat height could be different to GTR, so the position of the rotor might be different and you may need to consider the repositioning in addition to the diameter difference...
- Dohmar (payment cleared)
- Delta Force (payment cleared)
- SO17K (tbc)
- R33 Smash Daemon (tbc)
apparently the difference is very little, this is from a friend who was looking at the RDA line-up
"Hey do you know if the GTR rotors fit your Skyline? As far as i can see from the spec sheet they GTR ones are 324mm vs 310mm and th eonly other difference is the GTR ones are 53.8mm high vs 53.75mm..."
so that's a .05mm difference, which doesn't sound massive.
I'll start a thread in the braking section to see what people think, if it's not a huge job it might be worth getting bigger rotors if the price isn't much different.
Actually, is the price much different between standard slotted front/rear for the GTT and GTR?
probably not worth the hassle Daniel .. I'm sure Nissan engis knew what they were doing when they decided on the rotor sizes. Besides most of the braking is at the front due to the weight of the engine which is why the discs are bigger at the front. Slotted rotors should give you better than stock braking anyway.
don't know much, but i'd imagine bigger discs would give you better heat resistance as there is a greater surface area to dissipate the heat, and if there isn't much to modify and the prices are relatively similiar, could be a cheap upgrade ontop of the slotted upgrade
price wise front R34 GTT & R34 GTR is the same
but the rear R34 GTR is the same as the front (in slotted) and the R34 GTT is cheaper at the back.
R34 GTR front 324mm rear 300mm
R34 GTT front 310mm rear 297mm
It's only 14mm difference at the front, it's probably not worth mocking around with caliper adapter and stuff for such a small upgrade.
Unless you have an R33 gtst with 296mm front then some people upgrade this to a gtr front as there is more difference in size at the front.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
