glad to hear... cheers...
Group Buy #45 order list:
- scandyflick (payment cleared)
- heller44 (payment cleared)
- tx3_90 (waiting for payment to clear)
  • Replies 447
+1 Group Buy #45 order list:
- tx3_90 (payment cleared)
- VE35GT (waiting for payment to clear)
done
- JoshTypeX (waiting for payment to clear)
Rianto,
If possible I would like a quote on each of the following:
R32 GTR (late model)/R33 GTR/R34 GTR: F=7701S 324mm RRP $355
R32 GTR (late model)/R33 GTR/R34 GTR: F=7701G 324mm RRP $575
R33 GTS-t: F=7693S 296mm RRP $305, R=908S 297mm RRP $190
R33 GTS-t:F=7693G 296mm RRP $465, R=908G 297mm RRP $285
My aim is to select one of the above options and complete payment in time for the current GB. Delivery is to SA Adelaide 5125 area
Regards,
Matt
quotes sent...
- digitobi (payment cleared)
- whatsisname (waiting for payment to clear)
Closing tomorrow!
Just got home tonight and quotes sent...
- gwholxc (payment cleared)
- Josh_TypeX (waiting for payment to clear)
Just waiting for 3 last payments to clear...
EVOLV35, be quick if you wanna make it into tomorrow's cut off date.
If not, there'll be another on in May.
Cheers for the quick Pm mate, won't be able to make payment this time, (saw this thread too late) but since there will be one on in <ay i will go for that one. Thanks
Btw can you post the attatchment of the pics up here? it didnt work in the pm for some reason. :blush:
I will try it again. I was using Firefox on Linux (Ubuntu 8.10) and it didn't work, will try it with IE & Vista
pics are attached now. these are taken off my own car.
- Josh_TypeX (payment cleared)
- VE35GT (payment cleared)
- whatsisname (payment cleared)
all payments cleared, will send the order off to RDA ASAP!
Hi Rianto,
If possible, I would like a price on some front rotors to suit my r33 gts-t series 2. (normal slotted ones)
Is it possible to have them drilled as well? What is the advantage of doing this?
Can I also have a seperate price on rear rotors to suit? Oh, and red stuff pads as well pls?
Please excuse the noobness of this post.
Thanking you in advance.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
