glad to hear... cheers...
Group Buy #45 order list:
- scandyflick (payment cleared)
- heller44 (payment cleared)
- tx3_90 (waiting for payment to clear)
  • Replies 447
+1 Group Buy #45 order list:
- tx3_90 (payment cleared)
- VE35GT (waiting for payment to clear)
done
- JoshTypeX (waiting for payment to clear)
Rianto,
If possible I would like a quote on each of the following:
R32 GTR (late model)/R33 GTR/R34 GTR: F=7701S 324mm RRP $355
R32 GTR (late model)/R33 GTR/R34 GTR: F=7701G 324mm RRP $575
R33 GTS-t: F=7693S 296mm RRP $305, R=908S 297mm RRP $190
R33 GTS-t:F=7693G 296mm RRP $465, R=908G 297mm RRP $285
My aim is to select one of the above options and complete payment in time for the current GB. Delivery is to SA Adelaide 5125 area
Regards,
Matt
quotes sent...
- digitobi (payment cleared)
- whatsisname (waiting for payment to clear)
Closing tomorrow!
Just got home tonight and quotes sent...
- gwholxc (payment cleared)
- Josh_TypeX (waiting for payment to clear)
Just waiting for 3 last payments to clear...
EVOLV35, be quick if you wanna make it into tomorrow's cut off date.
If not, there'll be another on in May.
Cheers for the quick Pm mate, won't be able to make payment this time, (saw this thread too late) but since there will be one on in <ay i will go for that one. Thanks
Btw can you post the attatchment of the pics up here? it didnt work in the pm for some reason. :blush:
I will try it again. I was using Firefox on Linux (Ubuntu 8.10) and it didn't work, will try it with IE & Vista
pics are attached now. these are taken off my own car.
- Josh_TypeX (payment cleared)
- VE35GT (payment cleared)
- whatsisname (payment cleared)
all payments cleared, will send the order off to RDA ASAP!
Hi Rianto,
If possible, I would like a price on some front rotors to suit my r33 gts-t series 2. (normal slotted ones)
Is it possible to have them drilled as well? What is the advantage of doing this?
Can I also have a seperate price on rear rotors to suit? Oh, and red stuff pads as well pls?
Please excuse the noobness of this post.
Thanking you in advance.
