  • Replies 447
ok, hope I hear some news by tomorrow if not Friday.
if RDA brand not available you may get EBC D7122 & D7123 of the same quality & fitment in slotted.
Hey Rianto
could i please get a price for
Front and Rear standard slotted rotors
which pads would you recommend for daily use? Green or Red?
thanks mate
Jaye
Hi Rianto,
I received mine today.
They are the EBC (GD 7122/7123) Turbo Grooved ones. They look awesome.
These are not the gold passivated ones.
Should i still paint the Hat (Hub) to avoid rust?
Any help would be great.
I wouldnt' suggest painting it, as they may not look nice when they start to peel off. and it might be tricky not to get any paint layer on the hub contact point between your rims and the hub or the friction area where the pads contact...
plus they'll be behind the wheel most of the time it's not really that obvious whether surface rust is forming or not, as long as you use your car regularly that shouldn't be an issue, if not keep it in a garage/shed to reduce the moisture from overnight dew.
but if you want you can always paint the hub if you like. I can't stop you :-)
oh yeah, druz, i think based on your order it was suppose to be slotted in normal non-gold finish, but since they can't find RDA in stock, they use EBC which comes in grooved pattern but has normal non-gold finish. so in a way you kind of getting a little 'bonus' in the form of the slot & dimple patterns.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
