  • Replies 447
ok, hope I hear some news by tomorrow if not Friday.
if RDA brand not available you may get EBC D7122 & D7123 of the same quality & fitment in slotted.
Hey Rianto
could i please get a price for
Front and Rear standard slotted rotors
which pads would you recommend for daily use? Green or Red?
thanks mate
Jaye
Hi Rianto,
I received mine today.
They are the EBC (GD 7122/7123) Turbo Grooved ones. They look awesome.
These are not the gold passivated ones.
Should i still paint the Hat (Hub) to avoid rust?
Any help would be great.
I wouldnt' suggest painting it, as they may not look nice when they start to peel off. and it might be tricky not to get any paint layer on the hub contact point between your rims and the hub or the friction area where the pads contact...
plus they'll be behind the wheel most of the time it's not really that obvious whether surface rust is forming or not, as long as you use your car regularly that shouldn't be an issue, if not keep it in a garage/shed to reduce the moisture from overnight dew.
but if you want you can always paint the hub if you like. I can't stop you :-)
oh yeah, druz, i think based on your order it was suppose to be slotted in normal non-gold finish, but since they can't find RDA in stock, they use EBC which comes in grooved pattern but has normal non-gold finish. so in a way you kind of getting a little 'bonus' in the form of the slot & dimple patterns.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
