gary McCoy is probably the best at it, of the GP guys. When he had a decent bike and was in the top 5 he was pushing really hard. Braking so hard into corners that the rear of the bike unweights and slides all over the track.
The Supermotard guys are something else. Its a completely different style of riding. The bikes only weigh 100-140kg so they are the fastest bikes through the twisties. Power is between 30 to 80hp, and being a big bore single cylinder they sound like nothing else.
that happens to a lot of guys chaos.
couple of years ago in WSBK Ben bostrom's setup was great, ass end of the bike used to sway from side to side.
dads building a supermotard right now, but we wont be backing it in like that!
that takes bulk skill.
Grrr - his kawasaki has ample power to get it sideways. Power is not the issue, its riding style, and the power delivery of the bike, setup, etc. He came from a speedway background, so thats how he always rode.
Mini Me - brand new DR650, full staintune system, Laced 17" road wheels, airbox/filter mods, rejetted, geared down, new bars, strip weight, 2nd hand race tyres, suspension at both ends, should be fun. Only got 600k's on it, so its not even run in yet. I wont ride it too much.
One of the things i love about them, is that they are cheap to crash. :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
