  • Replies 287
Posted Images
http://au.youtube.com/watch?v=0LO2e57UtkE&...feature=related
this is the day I fell in love with skyline's, I sat on the back hairpin and was just blown away with the grip the Gtr had out of the corner, will never forget it, pitty the brakes didnt last!
The Sierra's were serious competitors on par with the GTRs at Bathurst (only have the 1990 to 1992 greatest moments from bathurst videos to base that assumption on) if only the reliability was sorted out
Yes this is true they were only restricted in the years after they thrashed the assss of every one then still bet them and the other teams turned around and said ohhh come on guys let us play ....... or we will make it V8s only sadest day ever GOD live the GTR king of them all........You are most childs dream to own one .........
Actually there's many reasons that they went to the V8 format that they have now...One being the GTR but do you remember the racing format back then??? Timed races?? BORING!! They had dwindling spectator and competitor numbers and if you watch any bathurst from back in that time they had everything from GTR's and sierra's to suzuki swifts to make the field up! They had to do something to make it viable, so the V8 format was born....
If i remember rightly as well, the sierra was only running 8 inch wide rear tyres?? With over 500hp outta em and rear wheel drive on an 8 inch wide tyre i beleive that traction was a major issue...And if you watch any of those races from that era every slow speed corner the sierra is in wheelspin! Twas an awesome car though and ahead of its time as was the GTR!
I've got a DVD from 1991 of highlights of the races and i know exactly what your saying about the grip outta the hairpin's at Mallala!! OH MY GOD!! So awesome!! LOL!!
They invented the V8 supercars to keep the GTR out. Having your arses whipped and handed to you 3 years in a row does that to the Holden-Ford community. Throw a GTR in the ring today and it'll still whoop them. :(
What was this thread about again? ... oh yeah ...
So who is is keen to take there car on the track??? keep the hooning off the streets :)
I'm upgrading my brakes soon. Sometime after that I'd be happy to take the "wagon" for a few laps.
Engine service - check
Auto serviced - check
Oil/filter change - check
Good rubber - check
Brakes - to come
generally as it hits 100deg C water temp, and probably 110 - 115 oil temp. Oil breaks down at 120deg C, and coolant will boil around 110 - 115deg C. As long as when you hit these temps, you get off the noise and cool it down for a few laps, you should be fine.
haha noo noo will definaly be keeping sober and eating my brain food before hand for this one lol. u gonna be there damo? this thread is too massive to retrace thru and find out :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
