hey guys the popping on de acceleration has been getting worse for awhile and last night at the drags made it ten times worse. Orginally i thought the cat had shit itself but i had it on a hoist today and the exhuast is all good. And there appears to be no exhaust leaks and no intake leaks and it is holding boost what can course this poping. It appears to be down on power as well. I am hoping that a spike to 16 psi last night down the strip hasnt affected the stock turbo.
its normal to have abit of popping, my pops it ass off normally :)
If you think its excessive or getting worse i would check for intake leaks, just simple things like tight hose clamps and all vacuum hoses are on tight with cable ties. What bov are you running? Could that be leaking slightly?
Also what ecu are you running? stock or tuned?
if the turbo is still boosting fine without funny noises it should be ok, a quick 16psi spike wont hurt it, continous high boost will.
Also remember it is summer now, turbo cars hate the heat so its normal to have a significant drop in power during the day aswell.
Edited by R34GTFOUR
lol yeah its good but mine sounds pritty bad more like a old shit box back firing but instead its poping lol i will check the cooler pipes and extra tomorrow. It has a stock ecu but its been retuned by toshi and i am running a stock bov
check your plugs for fouling,
my gtr runs pretty rich, and starts backfiring after about 2 months, especially in summer, the plugs will soot up, i just clean them and problem gone........
hope this works for ya
Edited by donkey
i will check the plugs there only alittle bit over a month old and the o2 sensor is good its not old at all and tested it a couple of weeks ago and i would mind the pop if it wasnt to excessive but it is quiet bad
I had a problem similar to this turned out to be a leaking o-ring in an injector.
however it can be a number of things a small vacume leak, plugs, afm, 02 sensor. since plugs and 02 sensor are newish i would look at clean afm, then change fuel filter (never know) then look for any fuel leaks
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
