I am planning to do my transmission service; I have couple of things to ask from you guys, please help. Thanks...
:3some:
1) What is the fluid capacity of skyline gtst r33 SII automatic transmission? (without torque converter)
2) Which oil is the best for r33? How much $?
3) Where can I get the service kit including the seal? How much $?
Thanks
https://www.sau.com.au/forums/topic/251992-gtst-r33-rb25det-sii-1997/
:P
Thanks
Why do you say without torque converter? There is very little oil in the pan -less than 2L I would guess - I used 12L by undoing the hose to the trans cooler, running the engine to expel 2L, then add 2L thru filler and repaet until the oil runs clean. Filter kit was around $100 but it is metal - you can just take it out and clean it. Any ATF will be OK - synthetic is better.
i used castrol transmax Z, just undo the sump plug on the bottom of the transmission pan and let it drain.
i used about 4.3litres from memory, just make sure you check your levels because too much or too little will screw with things.
also give mike at MV autos in adelaide a call.
he does the shift kits and can also supply you with a new filter for $33 i think.
He's a helpful guy anyway and should be able to answer any general questions you have
ill be using the transmax z stuff also. just not sure how much the actual whole system holds??? jsut unbolting the oil sump bolt wont get rid of all old oil. there is still heaps in the converter and what not. i used up 12L in my aristo so i might just do the same with the liner.....
you wont get all the oil out of the convertor just by servicing it. if the oil is dirty flush the system by undoing the cooler line at the front of the car an do as kiwi mentioned, this is easiest if you dont know what your doing
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
