GTRsean, that carbon fibre front lip look nice.
Cheers. Ended up selling it to one of the guys on here because over time it would end up getting damaged on my daily...
Pretty sure it's a garage saurus lip.
My LM GT3's slid out in the wet today (well more aquaplaned) and said hello to a gutter :D
This kinda stuff's fixable right? I called Magman, and I'll have to email him pics to get a quote... Not cracked, just needs rolling out, and the rest welding or whatnot. I explained to him they're the Nismo rims...
Also, Steve: Not sure those are legit LM's. I'm pretty sure they didn't make them in 16". I may be wrong though.
Had these for over two years now.
They suit the 32's!
These are 18x10's all round.
Only problem I have had is the inner rim cracking, from fatigue crappy Sydney roads etc.
Got em de buckled, rewelded and machined. Running 265 35R18 tyres all round, as I was running 255 35's, too stretched lol.
You know ive got a soft spot for these things
Whats the offset?
Also, what guard/lining mods have been done?
I had 18x9.5 on before, stretched 235's to fit under the guards as mines low. Currently on R33 GTR rims which will be replaced as soon as i find the right offsets and design for a nice 18'' but this time i want 18x10 :P
  • 5 months later...
My LM GT3's slid out in the wet today (well more aquaplaned) and said hello to a gutter ;)
Hey Owen,
I recently got my Lm GT1 18X10 shaved back for some gutter rash which was inherited when i bought the car... The Magman will prob charge u a large amount for these as the inside of the wheels need to separated from the othside of the rim as they need to reanodise the wheel. You can do separate this youself but it does take some time might be cheaper too.. just ask the place where u werre gone get it done at. The cost would be mainly due to the outside rim being aniodised. This is a surface coating which you will notice gives the outer part i.e the rim of the wheel a "shinner" look. When geting your wheels shaved back for gutter rash you loose this anionised effect.. in addition when they weld onto the rim to fill in deep gashs the aniodised finish may sometimes discolour... (purplish metal colour) so you should be aware of this before getting them welded.
Any way i reckon they are an awesome rims and pretty rare, so fixing them might be a good idea...you need to do the balance thou, if they gonna charge you too much then its prob not worth it.
Hope some of this information helps
Cheers
I got these as well, can't be that rare >_< . I got mine when I told the place that I bought the car from that I didn't want their cheap 18's. so they took 2 grand of the the price and put on some 17" lm-gt's. I was kinda happy though I aint completely sold on em.
Whats the offset?
I had 18x9.5 on before, stretched 235's to fit under the guards as mines low. Currently on R33 GTR rims which will be replaced as soon as i find the right offsets and design for a nice 18'' but this time i want 18x10 :rofl:
Hey Offset for these rim is +20
  • 1 year later...
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
