hi all.
doing an advanced driving course tomorrow and they ask that you have your tyres inflated to freeway/full load pressure
i dont have a plaque thingy inside my door telling me the pressure:(
they are 17*9 rims with 235's all round anyone know the pressures, are they always the same no matter which tyre
normal/full load?
https://www.sau.com.au/forums/topic/25204-tyre-pressure-help/
well for a track day, i would be putting around 40psi front and 38 psi rear (if you get normal oversteer)!!!
that is more than they say on those plaques but shoudl make it handle alot better and give more response!!
oh by the way it is illegal not to have that plaque inside the door/on the car!!!
where are you doing this course?
I would be putting 36 to 40psi in them, depending on what sort of tyres they are. The pressure limits should be listed on the tyre. Either way, my old Nankangs on the Commodore were only rated to 32psi but I ran them all day everyday at 36-38.
My current tyres have around a 50psi limit so they would probably be fine to around 55-60. But that's entirely useless so I generally run them at around 38-40 similar to what Craved said (more pressure up front).
I run 34 psi in my tyres (235x45x17), I use to run 38psi but I found that the centres of the back tyres were wearing out faster than the sides so I decreased the pressure abit, no problems now, good even tyre wear.
yeah, don't go over 36psi cold, if you are driving hard you'll get another 10psi in them as they warm up. Good HOT temps would be 40-45 depending on the tyre manufacturer's recommendations.
You can go a bit lower with low profile tyres, but really you get better handling (and worse ride) the higher you run them - can make a quite amazing difference....
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
