In regards to power supplies do not under estimate what's required, to put it simply.... 99.9% of PSU's that come already installed in cases are shit and have the potential to f**k up your brand new shiny hardware. I've used Corsair and Seasonic (pretty much identical and both made by Seasonic) exclusively for the past year or so on the builds I've done and these things can handle the amps drawn by high performance graphics cards and systems.
Something that might be worth considering is a mild overclock. For example to get 3.0GHz out of a 2.4GHz Q6600 is incredibly simple without the danger of having to over volt anything and risk damage. It's kind of a bargain because you buy a Q6600 and effectively (if so inclined) get a Q9650
  • Replies 63
trav how much video editing are u doing?
I am a computer reseller to production companies and video editors ect ect (www.stormfx.com.au if u want te see the company)
if you do alot of good HD video editing then $2000 for a machine will not last long at all. From a company like HP you will look more at 10grand for a video editing machine that will last a little while and has room for improvement.
If you want some more info pm me and ill send you some information, probably wont check this thread again.
Cheers,
Oh a gaming machine, 2grand is a good budget, get a machine built for that price that will do good damage to any game you get. ATI cards=poo... NVIDIA are top of the range hands down, thats why they are supported by all 3d applications and software. ATI are decent bang for buck, not great cards from my experience.
Gaming card, i currently have a GTX280 which goes well.
Hey All, my current PC (AMD Athlon XP2000) has done well for 5 years, but its time to upgrade!
It's been a while since i built a computer, and i havent stayed up to date, so need some advice on...
1. Should I aim for an entry level Intel i7 processor(eg i7 920 - 2.66GHZ /8MB), or spend the same money on a Intel Core2 Quad which should have come down in price with the launch if the i7. (eg Q9550 2.83GHz/12MB/1333FSB)
2. I want something to last me a few years, so looking at 8GB of RAM (4x 2GB sticks). Would DDR2 say 1066MHz suffice? Not sure if its worth the extra $ s to go for DDR3 1333MHz. I'm on a bit of a budget.
3. Looking at a Gigabyte video card, 9800GT 1Gig DDR3 with nVidia Chipset. Any comments?
4. Haven't started looking at motherboards yet, too many to sift through. want to sort out the above and then find a mb to match.
Thanks for any advice.
Just a tip.
If you decide to get 8GB RAM you must use a 64 bit operating system. 4GB is the maximum a 32 bit operating system will support....
Just a correction... max 32bit o/s can address is 3GB of ram.
Correction to your correction :happy:
It is actually 4GB however the video card also has ram that the OS must address so if you have a 512mb videocard windows will see 3.5GB of your 4GB ram
Hey Nismoid,
I'm thinking i should go the overclocking path. Some good results in the Feb PC User Mag.
Looking at the E8500 + CoolerMaster V8 which is approx the same price as a quad core Q9400 - but significantly higher results from their tests.
1. Is the motherboard you mentioned, Gigabyte EP45-UD3R, suitable for overclocking?
2. Trying to read up on the basics, do you need faster RAM for an overclocked machine? i was going with 800MHz DDR2 ram, but not sure if this should be 1066MHz, if i'm overclocking the CPU from 3.16 to 3.99MHz.
Thanks mate
Hey Nismoid,
Thanks mate
Your better off going a E8400 and putting the coin towards something else.
You don’t need the 9.5x multiplier of the E8500 to get to 4.00ghz
Simply using the 9x and around 450FSB and you should see 4ghz out of a E8400 on air without a drama.
My E8400 was running 4.3-4.4ghz on air with around 480FSB, and that was using OCZ 800mhz ram, which was obviously overclocked too around 1000mhz… it did crash during the 46degree days here in melb and I suspect I damaged the ram …
So currently testing that out to find out what's gone wrong… but otherwise 4ghz would be EASILY done in a E8400, and 800mhz ram (just read up about the ram your going to choose and if its capable of running higher with more volts etc)
If you want then 1066 would mean you wouldnt have to over clock at all... so upto you
The GB UD3R is probably one of the best of the entire P45 series for the price you pay vs what you get.
A simple google search will confirm this :huh:
It’s a generation up from the board I have now, which in itself is excellent for over clocking which netted me the above
Im actually thinking of putting my current mobo/cpu/ram into my media box and running it at stock voltages and see what speed i can get. And then build another on the UD3 board as I cant justify the i7 cost which is nearly 1k more for not as big of a gain
And then use my media PC as a folding@home PC to help medical research 24x7.. cause my media PC is just a little slow and i wanna use vista MC instead of XP :P
Thanks,
So is the E8200, E8300, E8400, E8500 and E8600 all the same processor, but with a different Clock Multiplier?
And to push the E8400 to 4GHz, you need to bump the FSB up a bit more compared with if you started with the E8500?
Is the E8500 able to be o/clocked any higher than the E8400? I've found this page, with lots of results, will have a bit of a read tonight.
http://www.ocforums.com/showthread.php?t=544848
Ye same familiy - core2duo.
There is even a E8700 out now almost running 4ghz stock spec as the manufacturing line has matured enough now to yield that level.
You can clock a E8500 a little higher on air (around 4.5ghz) as opposed to a E8400 mainly because of the higher multi meaning you dont need to pump the FSB as high.
Any good mobo will do 450FSB with ease, and the UD3 i believe will rattle 500FSB without much problem which is great for the price
So agian, thats why the FSB doesnt need to go as high with a E8500, being you get the 9.5x multi
eg:
E8400 - 460FSBx9 = 4,140
E8500 - 440FSBx9.5 = 4,180
Same output, one lower FSB... there is more too it and how multipliers work with vcore etc... but thats another day and not overtly relevant here :huh:
No harm running 460 through a E8400, as long as you get a "C0" stepping chip, it'll do it on a very low vcore, just a bit more than stock which is great for keeping temps low under full song... and its rare you'll ever be running @ full song in all honesty
It is, but at the end of the day you really aren't gonna notice it in general useage.
If you are benchmarking and so on or just pushing it for something to do, then ye.
But if your just going to game on it etc, just get the 8400, 4ghz on a low vcore and off you go.
the extra 300mhz you wont notice. Its like ram with 5-5-5-15 vs 6-6-6-18 timings... there is a difference but realistically you wont notice them
After all the words-of-wisdom and other research i've done, here's my proposed system...
Case: Coolermaster RC-690
PSU: Coolermaster Extreme Power650W
CPU: Intel Core2 Duo E8500
Cooler: CoolerMaster V8
MBoard: Gigabyte EP45-UD3R
RAM: 4GB Kit(2x2G)DDR2 1066 Kingston
OS: MS Win Vista Home Premium 64b OEM DVD
Monitor: 24” 2ms HDMI WS Acer P244WB
HDD: WD Caviar GP 1TB SATAII 32MB Cache IntelliPower
Optical: LG 22X+-DL DVR/RW Black
Video Card: Palit Radeon HD4870 1GB Sonic Dual Edition
Speakers: Logitech G51 5.1 155W
Desktop: Microsoft OEM Wireless 3000
This is coming in at approx $2200, the most expensive component being the Video Card.
Edited by Trav33
IMO the OCZ Vendetta2 is better based on may online reviews... and with the stock fan i can assure you its dead quiet.
I upgraded the fan to one that moves more air, and its louder etc as to be expected but in stock form i was very impressed for the price :)
IMO get WD 640's and run them in RAID... it works out the same price, and faster :)
And don't get a wireless keyboard if your gaming, same for mouse.
I have a Logitech G15 keyboard & G9 mouse... awesome combo i reckon as the G9 is a bit bigger and fits hands better
it'll be a good setup that will last for a good couple of years, if it ever feels slow (and heaven forbid software catches up to the hardware) you can just jam a newer higher end quad core on the 775 socket, which is what ill do if enough code/programs come out, but i doubt it
No, dual channel is just the ram itself, you can use one stick if you wanted.
lul wut
Double Data Rate and Dual Channel (Triple Channel for DDR3) are most definitely not the same thing. You also do need pairs to run dual channel as you need sets of three to run triple.
How horrid that you have to buy an OS. Nice LCD, pitch is a little high for my liking but looks like decent value for a 24". The E8500 will go past 4GHz no worries. Nice choice on the graphics, run pretty much anything quite well and still represent excellent value despite the drop in $AUD. I had a E8200 running 3.8GHz on an Asus Silent Knight before I got the E3110 and went water (so much quieter).
so what would be quicker:
2x 2GB DIMMs,
or 4x 1GB DIMMS?
I'm assuming dual-channel can only work with 2x DIMMS so the first option would be quickest.
That's not a dual vs non dual channel question, 4 dimms will run dual channel.
You'd want to 2x2GB though because there's less likely to be problems with RAM timing etc and you can get more RAM without throwing out the old.
Ah of course...
i should have compared:
1x4GB DIMM
with 2x2GB DIMM's
so as soon as you split the RAM over 2 DIMMs, you'll get faster access because the mboard will utilise dual-channel?
Ah of course...
1x4GB DIMM
with 2x2GB DIMM's
It then becomes a price/performance comparison. Large dimms are more expensive (and a little slower) but you can fit more RAM. Large and cheap dimms are much slower and by much it is in ms so will you notice it? Maybe not, yes if benching.
2 x 4 will give you more stability, 4 x 2 will give you lower timing (4-4-4-10, 4-4-4-12, 5-5-5-15)
Also have a look around how your chosen motherboard handles any RAM brand/config you consider.
I've got a rough idea what timings mean (thanks to wikipedia), and i think the kingston 1066 ram i'm looking at is 5-5-5-15 which is ok. but is the throughput important too? i saw some figure mentioned (i think MB/s), which was different from the speed of the RAM.
Been out of the computer scene for a few years, this thread+a couple PC User Mags have helped learn and try to get up to speed, but havent seen a memory comparison in PC user yet.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
