Basically, when im on the freeway doing 100kph, there is a humming noise when the car is in gear, when i change to neutral and role the humming goes away. I dont know if its coming from the gearbox or the diff, but its a quiet hum every second or so.....hum.....hum......hum......hum.
Any ideas? Im leaning towards it being a diff problem...
I have ruled out the problem being tyres or anything under the bonnet.
How long has it been since you got a wheel alignment?
cheap and quick way to rule out wheel balance, hub issues, etc , and most decent aligners will spot any damage suspension issues while they are at it.
Most likely your diff but its somewhat expensive to swap that out.
Edited by Liquidity
From what I have been reading and heard from people drive shaft re-balancing is rarely the cause.
I too have a driveline noice over 100k but I was told from another GTS4 owner who had the same problem it was the transfer box.
Does anyone know how to how to assess whether the transfer box can be making this noise?
A couple of things happen when you toss it into neutral @ 100kph:
Revs drop to idle (assuming your foot comes off the pedal at the same time!)
Load is removed from gearbox
Load is removed from diff
and in a GT-R / GTS4, load is removed from the transfer case and front diff.
So, it's possible it could be in the exhaust, but that is usually a "drone" (low pitch). If it were in the gearbox, the frequency would vary depending on engine revs (which gear) @ 100kph (hum....hum....hum.... vs hum..hum..hum..). If it were tyres, then the noise wouldn't go away in neutral.
Check fluid levels in the front diff, rear diff and gearbox. Maybe even change them. See what happens.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
