remember that LED's emit a brighter and more direct white light so you may end up getting a bit of a pink glow from your tail lights. I put one in mine that i had lying around and it didnt make much different. That is in a 33 GTST but.
That why I was wondering if I should go red or white but while I was browsing on ebay, a seller said to not use red led if the cover is red..
I was gonna say the exact same thing. Get red or they will turn out pink like the faded VN commodore brake lights you always see
may sound silly but do you think because red leds emit "red" light obviously when it passes through the red cover something happens to the light say it gets filtered maybe?? probably the reason why the seller says not to use red leds in under red tail light covers??
i dunno but ive seen some strange things happen when you pass coloured light through coloured filters.
I know it gets filtered and only lets the red part of the light through etc etc. Just thought it might look a nicer deeper red with red led's but maybe not. Take some photos when you get them in anyway.
And whats this funny thing that happens when coloured light passes through coloured filters?
opps i forgot to say in my post that i used a red multi LED bulb not a white one. I had the LED in one and a normalin in the one next to it and couldnt really tell the difference. The LED one was slightly reder i think.....
But yeah remember a normal globe works much different to an LED. a normal globe will emit a duller light but emits it over a wider area, The LED is concentrated light so if you can get a multi-directional one it would be better. And def get a red one... Ive seen white LED's in some that look pink as said above. Red will do fine, worked in my old VL just wasnt that visible in the daylight, is much better in the skyline tail lights
like when a green led is covered by a red film it comes up whitey grey instead of green. i tried to make my clock red to match my interior lights but meh...still looks better than green.
is it just me or are there some LED haters on this thread.
Its not like fitting 20" chromies which decrease performance and look ghey, leds are actually brighter and use less electrical energy which is why they are used in new cars.
I admit its up to the individual and is alot of coin for a largely aesthetic mod.
I like them cause they match the ADR LED high stop light mounted in the rear window.
Also i find silver or clear tail light surrounds -like on the new WRX look shit so dont get clear.
You want Red, but in my opinion of all the brake light LEDs I've tested, I'm yet to find a drop in solution that is brighter than the original bulb.....that's my I don't sell them.
The only thing I have found that are any good are some 3W T20 indicator lamps that are actually bright in daylight and do the job.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
