My 34gtt had a service recently and everything was ok besides front bushes. I think due to the front suspension being quite low, the front tension rod bushes are split and leaking? (obviously wear and tear also). Can anyone suggest what parts to put on to fix the problem? any rough cost estimate?
How big of a deal is this split and leaking? - just so i kno to either fix it this week or within the next few weeks...
I want to buy a set of coilovers, would that alone solve the problem? or is that different part altogether? sorry im a masive suspension noob!
Any help would be great!
Julz.
Edited by 1R34SON
Does your car pull to one side or wander over the road? Mine did with stuffed caster bushes.
With the bushes you can replace them with standard ones or go for adjustable ones. Most people go with adjustables, as this means you can increase the caster giving you more straight line stability and more camber while cornering. Whiteline, Superpro and Pedders all make adjustable caster bushes.
I paid $130 for adjustable bushes and $40 to get them press fitted, but I'm assuming you wont be doing the work yourself, so it'll be a little bit more than that when you factor in labour costs for rermoving the tension rods. Ring around and get some quotes
Btw, coilovers wont fix the problem at all - different part.
mine pulls to the left which i have been thinking is alignment, caster bushes and tension rod bushes are the same thing i presume? Thankyou for your help ill shop around then get quotes on install/fit cheers mate!
Yeah, caster bushes = tension rod bushes.
The worn bushes will be the reason it pulls to the left. If your bushes are split and leaking then obviously the cars aligment will be out.
Get the new bushes fitted and then get a wheel alignment. Should make the car alot nicer to drive.
Getting it sorted for roughly 300, 160 for bushes plus labour and another thing getting fixed included. lol mechanic showed me everything and explained bout the bushes. haha now I feel like a real idiot asking if new coilovers would fix it. Good to learn new things!
Cheers for the help!
No worries mate, seems like a fair price as well.
uhm
what exactly are the tension rod bushes leaking? =O
They are silicon filled, when they get old and start cracking the silicon starts to leak out.
Very common with the standard bushes. Whiteline bushes fixed my problem a few years ago. So much better for it.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
