unless they have created one in the last 3 months, they do not do one.
Only for S1 & S2 Stags.
If you speak to Mike & they do, please let us know. There are a few guys on here that would be very interested.
Edited by iamhe77
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376063
I spoke to Mike in September last year and they said they can do it. They don't have a spare valve body so they can swap it on the spot like they can the C34. From memory he said about 2-3 days to do the work.
Cheers
Andy
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376067
Cheers
Andy
I stand (sit) corrected.
So I guess they are not couriering it out to people in other states then?
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376073
try knox autos in rowville, and also there is this thing called capslock, when the light is on its BAD
Knox Autos = 4 speed box only at present.
I spoke to them and had to explain what the car was, let alone get a price on a shift kit.
unless they can get hold of the MV kit, I suppose.
Edited by iamhe77
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4376977
I was in adelaide over new years and was very tempted to get mine done.
Would be very interested in hearing from anyone who gets this done!!
And I will definitely be keeping it on the todo list - might not be this year though... :P
https://www.sau.com.au/forums/topic/253072-m35-shift-kits/#findComment-4379004
