hey guys, how much is it to replace a windscreen roughly (r32)? is it worth buying a used one and getting it swapped?
Couple of neighborhood kids thought it would be a good idea to chuck rocks at my house (got 2 smashed house windows and my windscreen damaged and house mates Lexus has a few dents in it). They threw rocks for around 15 minutes, couldn't really see where they were coming from as it was too dangerous to go outside. Cops showed up after 20 minutes but i guess they ran off after that. Has to be one of the houses behind our street .. cant wait to figure out who it was :angry:
Oh and also, if someone has a house for rent in south east anywhere ... ill take it. I've had enough of this northern suburb BS.
https://www.sau.com.au/forums/topic/253074-r32-windscreen-cost/
thats where you go to your gun shed, pull out the bean bag shot gun and start shooting back!
bloody little kids, if you have a younger person you know who goes to the local school , better set him up with some cash to fish them out.
Give National Windscreens a call. It was 3 years ago, but a brand new one was $180 fitted on site for my GTR. I wouldn't bother with a second hand one, personally.
As to the radio not working, R32's (well, GTR's at least) use a 'diversity' system which uses an antenna built into the front windscreen AND the rear windscreen de-mister grid as an antenna (there's a module in the LHR quarter behind the boot trim that has antenna and grid power connections, it acts as some sort of filter system to eliminate radio interference). Of course this assumes your still using the stock radio (unlikely.....). I disonnected the rear grid antenna connection and added one of those aftermarket Aerpro hidden antenna's. Works fine.
how s the reception?
damn man. i hate little kids...
kids started throwing plums at my house at night. but.. we hid and we lay in wait. for which we pelted their homo asses with water balloons and hosed the little mofos down till they started crying.
ambushing.... its teh shizzz
they did a farking shit job of it but meh what can you do
The important thing when having a windscreen replaced - and it doesn't matter who does it - is to make sure any damage to the paint under the old sealer is repaired BEFORE putting the new windscreen in. When they remove the old sealer they always scrape the old sealer off and can damage the paint, which could expose the underlying metal resulting in corrosion down the track (the new sealant only delays the inevitable). I've seen this on many cars and had to do the repairs, which in extreme cases involves lots of welding.
I usually use a high zinc primer or something like Kill Rust, but I also ask the installer to come back in a few days after he's removed the windscreen. That give me time to restore the paint, they usually don't mind, but I realise that might be difficult if you need the car back on the road quickly.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
