hey guys im wondering if its worth me selling my profec b spec 2 and getting a power fc for the new 260... how much will it all cost to get insalled etc etc... im guessing heaps and will it give me much improvment to a relativly stockish 260? (zorst) cheers...
https://www.sau.com.au/forums/topic/253076-power-fc-and-260s/
Yep, Adam, the R32/R33 GR-R PowerFC is the one you'll want for the 260RS.
Keep the Profec B, apparently it's better than the Apex'i boost controller that plugs into the PFC. It's a separate unit anyway, so seeing as you've already got the Profec B, you might as well use it with the PFC.
I've got a PFC in my car (mine was converted to manual before I bought it) and will be adding a boost controller soon, and I've been advised from quite a nfew workshops that the GReddy unit is the way to go!
Assuming you are selling the Profec B to fund the PFC?
Go the PFC and remove the restrictor, 14psi + good tune will unleash KW for sure.
Better option is both obvioulsy.
Ive used the profec B's before and a very good unit, pretty easy to tune and worked very well.
i would do yes... but if i could run both it would be better?? whats the benifit with having the hand controller? ive found one for 850 with outa a controller?
The hand controller is good to have to keep an eye on your vitals of the engine - it can display Knock levels, injector duty cycle, engine revs, road speed, timing, various temps, etc.
If your car isn't running right, it's a good device to check quickly to see if any of those things are factors in it not performing properly.
It would be better to run both yes.
As someone else mentioned the hand controller is a good way of checking vital sensors etc. Very handy, i dont use one in mine as i have a 10yr old who would probably think its a video came like NFS. I do want to get one though eventually so i can monitor things.
Edited by msports180
Cost for tuning it will vary depending on with it is a D-Jetro map sensor power-fc or if it uses AFM's. For a complete D-Jetro tune, you are looking at half a day and around $850 (last quote I received). That will get you full idle, cold start, cruise and power/heavy load/full boost and a power run and dyno sheet to take hom and put up on the fridge.
Dunno how much it costs to install... whilst it is supposed to be "plug and play", you would still want to have someone who knows what they're doing install it... if only to have someone to blame/do the free labour to fix it if it goes pear shaped, develops that strange misfire or just doesn't run right!!
To be perfectly honest, without the hand controller, you really are driving in the dark. The sheer amount of info you can pull from the controller is awesome. Fantastic for diagnostics. Also, adjustability is on the fly... not that you should need it if the tune is done properly, but can be handy if you get stuck with sub-standard fuel etc or are experiencing high knock/pinging.
I don't think that the power-fc's are compatible with the Nissan CONSULT test gear, so that's another reason to have the hand controller.
I bought my RB26 conversion stag recently and found that the car was overfuelling something chronic. Looking at the sensors under the "etc" screen I could see that it is probably due to the hidden map settings (can only see these on the laptop software) required to compensate for the fact the rear oxy sensor has been wired in wrong. Also found out that the tuner used the wrong injection compensation for the aftermarket injectors and used an incorrect injector latency. He did a pretty good job despite all the basic errors made, but my point is that I would be none the wiser for if I had no hand controller. (Now I just need a full tune to rectify the mistakes = $$). Prob would be staring down the barrel of spun bearings and glazed piston walls due to the overfuelling in short order too!
if you want power, you need to keep your boost controller... besides theres nothing wrong with toggling between a high 20 or so PSI setting which your tuner will use for tuning the power-fc and then toggling to a lower boost when driving around town. It's a good tool to have. Plus the ability to control how late the solenoid starts working and the gain it regulates boost with, will ensure you don't over boost and that you reach peak boost sooner.
Good luck with raising the dosh, maybe a lotto ticket? Just gotta remember that its $1K to buy the power-fc then... $x00 to install, $850 to tune. so quickly puts you upwards of $2K !! But well worth it of course. :D
thanx heaps stagtr... awesome username aswell actualy lol.... possablility for the new plates ;)
ive borrowed a little more than what i need... not 2 grand but yeah. give me alot more info on it!
a mate had 1 in his 32 gtr so i might speak to him... i dont want to go over board with the 260 i dont think... well just yet.. wait until i drive it n stuff... might get addicted! :(
wheres a good place to start modding it?
ive got a profec b as i said
its got a cat back
fuel cut defender
heavy clutch
intake
n a few other bits n peices i guess
will the power fc rule out needing a safc, afm all that jaz... the way i understand it is getting the intense pfc will be virtualy all i need...
ill have boost, fuel, air and it will b flowing well...
its got a cat back
fuel cut defender
heavy clutch
intake
Best place to start modding is the exhaust (if it's not already done), as per usual.
The PFC will replace the need for an SAFC, as it will handle fuel, timing, etc. all within the PFC itself. If you want to get rid of your AFMs, then get the D-Jetro version of the PowerFC.
The latest issue of High Performance Imports magazine has a few articles on the best way to get the max out of a GT-R, so this should easily apply to your 260RS.
ah k cheers.. ill speak to just jap about the front pipes as its a cat back on there. and the d jetro ones are still like 1500 lol... might be worth waiting for the $ to go down a lil.
With the power-fc you can get rid of your fuel cut defender and make back a couple of dollars to the cause!
Keep an eye out for second hand power fc on ebay. Also some of the larger import companies get them in as well, they return the car to stock for compliancing... maybe the owner didn't want it re-installed (highly unlikely) or maybe they just never knew it was in there when they imported it... or it could have been imported by the importer for his own yard and reckons he can get better coin for it if sold spearately. It's a cheaper way to do it and allows you to save for the purchase in the meantime. Just Jap and Mod Your Car websites seem pretty expensive for most parts for my liking.
For mods:
I reckon you should always start with handling then move to power... you've got to be able to harness those horsies to make em work for you.
I would look at new rubber. It is the best performance upgrade you can get for your car if it is running on cheaper tyres (eg Nankangs and the like). You need to replace em every coupla yrs anyway so its not like its a non essential component, they're what puts the power to the ground, gives cornering traction and helps stop you... it's crazy to skimp on these. You will be amazed at the difference it makes. Do a search... I know that Goodyear are running out the older symmetrical Eagle F1 GS-D3's at the moment and you may be able to score yourself a deal.
People mess around with ghetto bling rims, and get no ride improvement... I wouldn't waste money on new wheels unless you can't get suitable rubber in the stock sizes... or you spot a set of cheap second handies.
Good brake pads and a disc machine will help too (if you are going to be flogging it around psuedo circuit racing).
Aftermarket coilovers are expensive, and unless yours are shot already or you are throwing the bus around alot, it prob wouldn't be good bang for buck. Better to invest in uprated swaybars for reduced body roll and sort out any camber issues you may have to ensure best contact patch.
Now for power...
Exhaust is a great way to free up your flow... high flow cat, single rear exhaust . Make sure you get a removable silencer with your cannon... your ears will thank you as will everyone else. Most will do little to choke the flow. If you want loud, you can always romove the silencer, its pure gold.
I'm showing my rb engine ignorance here (only had the car a couple of months!), but I think the GT-R may have come out with the more fragile ceramic wheeled turbines? If you want to make power, you'll need to up the boost safely. So if ceramic wheels, will need steel wheeled turbs and probably new injectors to cope with all that extra air. The rb26 feels like a dog off boost so you wont wanna go too large a compressor/turbine setup... peak power figures look great on dyno sheets but don't always translate to usable performance on the road. Can always sacrfice some flow for a bit better/earlier boost response. Then you wont be smashing to redline all the time and will be that much kinder on the donk.
Can anyone comment on the stock FPR, I'd say you prob wont need to touch the fuel pressure regulator or fuel pump... power-fc and a tune will do the rest. New turbs and injectors will cost a LOT of money.. maybe best to milk what you've got in the stock setup.
New exhaust manifolds are relatively cheap though, but prob not worth the labour if you aren't replacing the turbs.
Exposed intake pods are bad... instant defect and the temp of the air you suck in is pretty average, despite how big your intercooler may be. Shielded pods or use the stock airbox w/ high flow panel filter.
Adjustable cam gears allow from more intake/exhaust cam/valve overlap which will give you more up top (and a little less down low if I am not mistaken).
If you replace the oil pump with an N1 or tomei/greddy you can run closer to rev limit for longer and safer, but you need to weigh up how you are gonna be driving your car I guess.
Bugger, shoulda read the other posts... see HPI/Fast Fours/Hot fours special issues and Tech sections for modding RB26's, they'll have all the good gouge
P.S. I reckon that a oil filter relocation kit is a must... that filter is a nightmare to get off/out without spilling oil all over the right side of lower engine bay... need to do a frickin degrease after an oil change!! (Damn Nissan engineers!! nice donks though)
I'm looking for one right now if anyone has a spare?
yeah nice... im not after any thing massive... and at the end of the day its all massive $... i just want a car i can buzz round in day to day and over take... crank threw sum bends and give it a launch every now and then... most of the stuff i will do my self... and i guess once i actualt feel how it is i cant make much judgment... it may be enough for me as is... what is a safe boost level? and how have you all god ur pro fec bs set up?? set gain all that jazz??
cheers :(
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
